Temperature 1.6 liter TD with intercooler, 80hp, VW Passat 35i, 1989
xizang74
Post26-04-2004, 1:03    Subject: Temperature 1.6 liter TD with intercooler, 80hp, VW Passat 35i, 1989 Quote
What is the correct temperature for the engine mentioned above? Does the mixing ratio of water and coolant affect the temperature?
Thank you very much!
Matthias.
DocSnydor
Post26-04-2004, 7:05    Subject: Temperature 1.6 liter TD with intercooler, 80hp, VW Passat 35i, 1989 Quote
I think you need to formulate your questions a little more precisely...
In my opinion, the water/antifreeze ratio doesn't affect the temperature. However, it changes the time it takes for your engine to reach operating temperature...
(please correct)
What problems are you having?
xizang74
Post26-04-2004, 8:43    Subject: Temperature 1.6 liter TD with intercooler, 80hp, VW Passat 35i, 1989 Quote
I replaced my ZKD (cylinder head gasket) and ZKopf (cylinder head), which I had to replace due to temperature problems. Now, the temperature gauge in my car always reads around 90°C (194°F) and slightly above. Before, the operating temperature was always around 80°C (176°F), a bit lower. When we refilled the coolant, we didn't mix it in a 1:1 ratio, but perhaps a ratio of 1:4 water to coolant. The temperature gauge reacts very quickly to stress, and high-revving driving and inclines immediately cause a rise in temperature. However, it never goes above ~95°C (203°F). Having had a bad experience, I'm not willing to invest any more money in that.
matthias
Post26-04-2004, 9:12    Subject: Temperature 1.6 liter TD with intercooler, 80hp, VW Passat 35i, 1989 Quote
Hi.
Diesel thermostats typically regulate the engine coolant temperature to 87 degrees Celsius.
The sensor for the display is located at the engine outlet, so a reading of 80 degrees is not entirely possible.
90 sounds pretty good.
How do you measure the temperature? The reading on the dashboard is just a rough estimate for (too cold) or (too hot) - I wouldn't pay much attention to the numbers displayed.
No new posts P0634 - Internal PCM/ECM/TCM temperature too high General Tips
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate control, Passat, 1997, temperature reversed Transmission, Chassis, Body & Interior
No new posts Lupo 3.0: AGR Valve Replacement Guide Diesel Engine Technology
No new posts Low Pressure System: Tank Flow Rate (L/min) Diesel Engine Technology
No new posts Fuel Consumption (L/h): Is the Resolution Too Coarse? On-Board Diagnostics (OBD)
