wuze60 Guest
13-05-2002, 20:55 Subject: Larger Intercooler: Does It Improve Performance? |
Hi everyone!
Since I'm currently in the process of installing a nice RS front bumper on my 4er, I'm also considering installing a larger intercooler in the center of the bumper at the same time.
What do you think about it?
Would that provide more performance, or should I just forget about it?
I would be happy to read what you think about it.
Translated on 21-09-2026, 2:53.
Stefan Guest
14-05-2002, 12:17 Subject: Larger Intercooler: Does It Improve Performance? |
Please measure the intake air temperature behind the air mass sensor.
If the temperature exceeds 40°C under load, it might be a good idea to do something about it.
Translated on 21-09-2026, 2:54.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
14-05-2002, 12:31 Subject: SEO: Best Tips & Tricks for Success |
...before you drill holes in the intake manifold: you can read the charge air temperature via the diagnostic interface, and there is already a sensor in the intake manifold for this purpose in TDI engines.
Translated on 21-09-2026, 2:55.
Profile PM WWW Garage |
wuze60 Guest
14-05-2002, 18:17 Subject: Tip: Another helpful hint. |
...before you drill holes in the intake manifold: you can read the charge air temperature via the diagnostic interface, and there is already a sensor in the intake manifold for this purpose in the TDI.
Greetings, Rainer
Thanks, everyone!
I'm going to take my laptop with me tomorrow morning and take some measurements.
Okay, so if the temperature goes above 40°C, then a larger intercooler will be beneficial.
Would it really make a significant difference if I increased the air temperature to, for example, 34°C, or even lower?
Thank you in advance.
Translated on 21-09-2026, 2:56.
Henrik Guest
24-04-2004, 23:34 Subject: Larger Intercooler: Does It Improve Performance? |
Hello!
I'm considering installing a larger intercooler.
My ALE (presumably referring to an engine management system or similar) is chipped, and it runs at 0.9 bar of boost pressure under full load.
He seems to be misfiring slightly when accelerating, especially at higher RPMs (I suspect he might need more air in the combustion chambers... perhaps a larger throttle body?).
Now, I would like to install a second or a larger LLK (likely referring to a liquid-cooled oil cooler), perhaps one from a T4 with a 2.5 TDI engine.
Does it make sense, and is it appropriate?
Thank you!
Translated on 21-09-2026, 2:57.
DocSnydor Guest
26-04-2004, 6:52 Subject: Larger Intercooler: Does It Improve Performance? |
RTFM !!!!
/viewtopic.php?t=3253
Translated on 21-09-2026, 2:58.
26-04-2004, 9:16 Subject: Larger Intercooler: Does It Improve Performance? |
@ Henrik
My 1Z engine isn't chipped and also produces 0.9 bar of boost pressure (completely stock).
What is the connection then?
m; Transparency, Teamwork
Translated on 21-09-2026, 2:59.
Profile PM Garage |
Rudi Guest
26-04-2004, 10:02 Subject: Larger Intercooler: Does It Improve Performance? |
Some people also refer to a cheat device as a chip  .
Best regards, Rudi.
26-04-2004, 10:38 Subject: Larger Intercooler: Does It Improve Performance? |
Okay, my "chip" has a resistance of 550 ohms and provides more than 17% more thrust  .
The LLK (likely referring to the EURO3 AHU) probably still has some reserves.
My 1Z (which is the engine code AHU) only heats up to a maximum of 30 degrees Celsius above the outside temperature at the intake manifold.
m Transparency, Teamwork
Translated on 21-09-2026, 3:00.
Profile PM Garage |
Henrik Guest
26-04-2004, 13:28 Subject: Larger Intercooler: Does It Improve Performance? |
RTFM !!!!
Yes, I have already read that.
Essentially, it states that a larger language model is pointless without further fine-tuning.
I have a chip that, when used with the larger LLK, is more effective, which is why I'm asking if the T4 LLK will fit with my setup. Sorry about that.
But now, a standard 1Z engine also has a pressure of 0.9 bar?
I don't know what the boost pressure was before, but now (since the chip was installed 2 years ago), it's 0.9 bar at full load (and it accelerates a bit faster and has about 10 km/h more top speed).
'So, I could potentially increase the LD (low-pressure) further, maybe to 1.1 bar. Can I achieve this in a similar way to how I adjusted the TD (turbocharger boost), by simply disconnecting the hose to the control unit? Or are there other, more cost-effective methods?'
Translated on 21-09-2026, 3:02.
Bertil Profi-Schrauber
26-04-2004, 14:07 Subject: Larger Intercooler: Does It Improve Performance? |
Henrik wrote: | | ... or are there other cost-effective options? |
Can you find everything using the search function "10 cent tuning"?
Okay, ich bin bereit. Gib mir den Text.
Okay, I'm ready. Please provide the German text you want me to translate. Gruß Bertil
Translated on 21-09-2026, 3:03.
26-04-2004, 14:29 Subject: Larger Intercooler: Does It Improve Performance? |
You definitely didn't affect the turbocharger's boost pressure by modifying the EGR system!
The TDI regulates the pressure electronically, so it's not as simple as just turning a knob.
Why do you want more pressure? You're driving with DIESEL, not air.
Here's some more information about printing:
The Y-axis represents absolute mBar values (so, at 2000, you subtract approximately 1013 mBar, leaving almost 1 bar of boost pressure).
Everything's fine! 1Z. Transparency, Teamwork
Translated on 21-09-2026, 3:05.
Profile PM Garage |
