ObenbeiMutti Guest
27-04-2004, 14:06 Subject: Leadership waste llgek. Turbomotor: From Winter to Summer?? |
Hello everyone,
I was wondering if there is a noticeable or measurable performance deficit in an electronically controlled TDI engine with an intercooler when operating in high air temperatures.
The density of the intake air, and also the performance of the intercooler, should theoretically be lower. Does the electronics compensate for it?
I mean, in my subjective opinion, I already feel a reduced engine performance. Have you had similar experiences?
Thank you for your contributions.
PrivatBereich Guest
27-04-2004, 14:58 Subject: Leadership waste llgek. Turbomotor: From Winter to Summer?? |
[img][/img]
Hello ObenbeiMutti,
Since you're new here and have already asked a third question that has been extensively discussed, I need to direct you to the search function.
Try using the search term 'summer weakness'; you'll find two results within the top ten that perfectly reflect your topic. Please search first, search again, and then ask.
Thank you.
-Privatehttp://www.cheesebuerger.de/smilies/schilder/10.gif{MARKER}
