ESP Light On: What It Means & Troubleshooting
ckone
Post02-05-2004, 15:09    Subject: ESP Light On: What It Means & Troubleshooting Quote
Hi!
'Since yesterday, I've been having a problem where the ESP light sometimes comes on. Then, if you restart the engine, it goes away again.'
I have now read out the error code.
18265 - Engine speed signal from the engine control unit (ECU).
Error message from the engine control unit (ECU).
What could that be? I've already deleted the error before, but it keeps reappearing after a while.
Okay, here's the translation:
Thank you.
P.S. I have a Polo 1.9 TDI with the AXR engine.
Translated on 21-10-2026, 5:59.
Martin R
Post02-05-2004, 15:27    Subject: ESP Light On: What It Means & Troubleshooting Quote
Is there a fault code stored in the engine control unit?
If not, is the following possible:
(It might be a bit of a stretch, but I've encountered a similar case before.)
Perhaps the engine control unit is briefly shutting down (possibly due to a faulty relay for power supply), which is why the ESP is temporarily not receiving a signal.
Translated on 21-10-2026, 6:00.
ckone
Post02-05-2004, 15:38    Subject: ESP Light On: What It Means & Troubleshooting Quote
The engine control unit (ECU) shows the following error:
17911 - Air intake system leak detected.
It's strange, I actually thought I had found the leak, but a screw was missing from the EGR valve (for some reason).
Could the error be related to another error?
Translated on 21-10-2026, 6:01.
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP Light On: Brake Booster Failure? On-Board Diagnostics (OBD)
No new posts ESP Light On After Tuning: Troubleshooting Diesel Engine Technology
No new posts ABS Light On: Troubleshooting & Solutions Transmission, Chassis, Body & Interior
No new posts ABS Light On: Troubleshooting Air in Brake Lines On-Board Diagnostics (OBD)
