AAZ Turbo: Boost Pressure Increase & Limits!
zivi
Post01-05-2004, 15:03    Subject: AAZ Turbo: Boost Pressure Increase & Limits! Quote
Hello!
I've installed a low-pressure fuel kit (LLK) on my AAZ engine and now I want to increase the boost pressure!
Can someone tell me what the maximum mileage is before it starts to suffer damage? And what should I be aware of? The engine has a mileage of 30,000 km.
Best regards, Zivi.
Translated on 07-09-2026, 4:42.
Stukov
Post02-05-2004, 17:21    Subject: AAZ Turbo: Boost Pressure Increase & Limits! Quote
'The standard boost pressure is between 0.6 and 0.7 bar. However, due to the low-pressure cooling system and reduced charge air temperature, you can increase it to approximately 0.9 to 1.0 bar. The turbocharger is essentially the same as the one used in the 90 hp TDI models, which operate with similar boost pressure values.'
Overall, it's impossible to say exactly what the engine and turbo can handle, as there's an increased stress on the components, and you need to be aware of that. Using a low-temperature coolant (LLK) helps to mitigate this somewhat. Personally, I have no concerns about running this engine with a boost pressure of 0.9 to 1.0 bar. 'Tuners' also typically use values around this range when an intercooler has been installed at a significant cost.
But everyone has to know that for themselves, so don't blame me if something happens anyway. icon_wink.gif
Translated on 07-09-2026, 4:44.
zivi
Post03-05-2004, 21:14    Subject: AAZ Turbo: Boost Pressure Increase & Limits! Quote
I thank you nonetheless! icon_biggrin.gif Finally, someone who has a concrete statement!!!! icon_lol.gif
Translated on 07-09-2026, 4:45.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Turbo Upgrade for Mazda DiTD Diesel Engine Technology
No new posts Jerking/Stuttering with TD? Who can help? Diesel Engine Technology
No new posts AFN Turbocharger Upgrade: Boost Performance Diesel Engine Technology
No new posts AFB High Fuel Consumption: Common Causes Diesel Engine Technology
