Remove exhaust for test drive?
Manuel V
Post03-05-2004, 8:04    Subject: Remove exhaust for test drive? Quote
I want to test if my exhaust system has any leaks. Right now, I'm having a problem because the pipe connecting the turbocharger to the catalytic converter is completely blocked.
'What do you think, can I simply unscrew the exhaust manifold in the engine compartment, secure it with a wire, and take it for a test drive? Or am I already risking a fire hazard during that test drive? The exhaust gases would probably be pushed out mostly by the airflow. On the other hand, it's also possible that after the test drive, the entire engine compartment will be full of soot. Has anyone else perhaps had this problem before?'
Best regards, Manuel.
Translated on 10-08-2026, 20:47.
Gremlin
Post03-05-2004, 8:56    Subject: Exhaust Removal for Test Drive? Quote
Or am I already running headfirst into a test drive that could lead to a fire hazard?
Don't worry, it just takes a little longer for diesel engines to start making that knocking sound.
The exhaust fumes would probably be pushed out to a small (or large?) extent by the airflow. On the other hand, it could also be that after the test drive, the entire engine compartment is full of soot.
I'm starting to get worried... why are they installing insulation panels and films everywhere? Rubber and plastic don't like getting too hot.
guy...
I'm thinking of making a makeshift side pipe out of spare parts that can be attached to the door using wire hangers. It has proven quite useful as an 'emergency exhaust.'
CU Gremlin.
Translated on 10-08-2026, 20:49.
eike
Post05-05-2004, 18:15    Subject: Exhaust Removal for Test Drive? Quote
'What do you think, can I simply unscrew the exhaust manifold in the engine compartment, secure it with a wire, and take it for a test drive? Or am I already risking a fire hazard during that test drive? The exhaust gases would probably be pushed out mostly by the airflow. On the other hand, it's also possible that I'll have the entire engine compartment full of soot after the test drive. Has anyone else perhaps had this problem before?'
Hi there,
Why do you want to remove the exhaust for leak testing? I can simply hold it in place at the back. Then you'll quickly hear if there's a leak.
Greetings.
Eike.
Translated on 10-08-2026, 20:52.
Avatar-Jan6K
Post05-05-2004, 20:02    Subject: Remove exhaust for test drive? Quote
"Hi,"
"I also pondered that point... I think when he says 'dicht,' he means that something is blocked or clogged, which it shouldn't be."
January.
1Z5 CFHF / AHB H4D
Translated on 10-08-2026, 20:53.
No new posts Exhaust Temp Sensor for AFN Manifold Diesel Engine Technology
No new posts VA Screw in Manifold: How to Remove? Diesel Engine Technology
No new posts Turbo Adapter for Exhaust Manifold Diesel Engine Technology
No new posts No Downpipe Needed: Turbo Performance Boost Diesel Engine Technology
