Which diagnostic adapter?
Gorchel
Post06-05-2004, 8:05    Subject: Which diagnostic adapter? Quote
Hello.
I'm interested in a diagnostic adapter for my Skoda Fabia, but I'm a bit confused because there's such a wide selection available. Therefore, my question is:
Which adapter is recommended for 'hobby diagnostics' (e.g., reading error codes, modifying comfort functions, etc.)?
Thank you very much for your suggestions.
Ritchi.
Translated on 05-07-2026, 14:01.
Post06-05-2004, 11:44    Subject: Which diagnostic adapter? Quote
If you want to adapt control units, you need the full version of VAG-COM.
Okay, here's the translation:
"So, either this one:"
http://shop.dieselschrauber.de/product_info.php/products_id/45
Or the professional adapter (HEX-USB+CAN, VCDS):
http://shop.dieselschrauber.de/product_info.php/products_id/46
Translated on 05-07-2026, 14:02.
Gorchel
Post06-05-2004, 11:59    Subject: Which diagnostic adapter? Quote
Hi.
Thank you for the response.
How about this adapter?
http://shop.dieselschrauber.de/product_info.php/products_id/36
Is it significantly cheaper, but does that mean the options are severely limited?
Translated on 05-07-2026, 14:03.
x world one
Post06-05-2004, 12:08    Subject: Which diagnostic adapter? Quote
You are missing the full version of VAGCOM, and you only have a serial port interface. The latter is not a problem if you still have an NB with a serial interface. With the included shareware, you can only log and read data, but as far as I know, you cannot set anything.
"For the adaptation, you'll need the full version, so that would be this bundle."
Spritmonitor
Gorchel
Post06-05-2004, 12:19    Subject: Which diagnostic adapter? Quote
Okay... I understand. And if this device also supports USB, that would be even better.
Thank you very much for your great help.
Ritchi.
Translated on 05-07-2026, 14:04.
x world one
Post06-05-2004, 13:54    Subject: Which diagnostic adapter? Quote
Only the last adapter recommended by Rainer supports USB!
I also ordered that one, and I hope it arrives soon http://shop.dieselschrauber.de/product_info.php/products_id/45.
Spritmonitor
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Which charging cable or adapter for VNT17? Diesel Engine Technology
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts Turbocharger: Which One Is Best? Diesel Engine Technology
