PDA und Bordcomputer, VAG-Check, VAG-COM, VCDS | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Uwe@Ross-Tech
Post01-05-2004, 19:02    Subject: Quote
Check out this error memory with multiple errors.
VAG-COM or VCDS:
http://www.ross-tech.net/Eric/VCheck/VCTDIFaults1.png
VAG-Check:
http://www.ross-tech.net/Eric/VCheck/VCHTDIFaults.png
Not all errors are being displayed!!!
Measurement values with VAG-COM:
http://www.ross-tech.net/Eric/VCheck/VCTDIMB-3-12.png
The same applies to our VAS-5052 'reference device':
http://www.ross-tech.net/Eric/VCheck/5052TDI003.png
http://www.ross-tech.net/Eric/VCheck/5052TDI012.png
And with VAG-Check:
http://www.ross-tech.net/Eric/VCheck/VCHTDI003.png
http://www.ross-tech.net/Eric/VCheck/VCHTDI012.png
The VAG-Check apparently shows several errors when displaying the measured values.
Conclusion: The VAG-Check cannot really be considered a serious tool.
-Uwe-
Translated on 03-09-2026, 3:21.
Gremlin
Post03-05-2004, 5:16    Subject: Quote
Come on, Uwe, just do it and create a small Palm OS version.
Reading out errors and modifying adaptations/codings would already be sufficient for me. icon_wink.gif
CU Gremlin.
Translated on 03-09-2026, 3:22.
knubbi
Post03-05-2004, 9:10    Subject: Quote
jajajaja, please!!!!!
Translated on 03-09-2026, 3:23.
sulzi
Post04-05-2004, 7:05    Subject: Quote
hi everyone,
Yesterday, I experimented with the 'vagcheck' software on my PDA (Pocket Loox 600). It works quite well with the engine control unit, but I couldn't establish communication with the other devices.
My impression of the software is that it is still very unfinished. Some of the functions behind the buttons are not yet working, and logging is also not functional.
However, it doesn't seem like there's anything decent on the market that's suitable for PDAs, so this is better than nothing.
Sure, here's the translation:
'Hi Sulzi'
microwire
Post10-05-2004, 8:00    Subject: Quote
@uwe_rosstech
The reason why vagcheck doesn't display all errors seems to be that not all errors are listed in the FaultCode.txt file. However, this isn't a problem, as you can simply copy the error code and its description into your program and extend the FaultCode.txt file.
Or simply decode the contents of the 'codes.dat' file and then copy them into the 'FaultCode.txt' file.
Furthermore, the FaultType.txt file is supplemented with the error type information.
It probably doesn't have the quality of VAG-COM, but it's still quite amusing.
MW
Translated on 03-09-2026, 3:25.
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Onboard computer 206 with RGB LEDs Upload
No new posts G IV on-board computer flickering Diesel Engine Technology
No new posts Audi A4 8E: Retrofit GRA & Onboard Computer On-Board Diagnostics (OBD)
No new posts Audi C4: Upgrade your dashboard computer Transmission, Chassis, Body & Interior
