Engine Misfire: Humming Noise When Idling
Martin L.
Post15-05-2004, 10:19    Subject: Engine Misfire: Humming Noise When Idling Quote
hello
I have a Wendland tuning box installed in my Ibiza 6N with the AFN engine.
Since then, I've had a low-frequency humming noise (brrrgrrr) that I can particularly trigger in the following ways:
The car is stopped, in first gear, idling with the clutch pedal slightly depressed.
Press the clutch. The engine shakes for about 3 seconds and then runs normally again.
The sound is almost like a faulty bearing.
I don't understand why the noise fades away so quickly.
'Yesterday evening, the noise appeared on its own for the first time and didn't go away even when I tried to let the engine idle. However, if I put it under load or increase the RPM to 1200, the noise disappears.'
Could it be the dual-mass flywheel? Mine seems to be worn out. When changing loads, I can feel a 'thump' up to the fourth gear, which I believe is due to the dual-mass flywheel.
Please tell me that this isn't something really serious, like a main bearing or connecting rod bearing issue, or something like that!
Translated on 13-10-2026, 4:08.
Post15-05-2004, 11:02    Subject: Engine Misfire: Humming Noise When Idling Quote
Martin L. wrote:
The car is stopped, in first gear, idling with the clutch slightly depressed.
Hi Martin,
The symptoms, to me, suggest a slightly over-revving idle, which is often caused by poorly designed components or incorrectly configured control units.
If you can eliminate the "problems" by temporarily disconnecting the box, I wouldn't worry about it any further icon_wink.gif.
Translated on 13-10-2026, 4:11.
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tachometer Light Flashing: Causes & Fixes Diesel Engine Technology
No new posts Whistling Noise Engine BLS: Causes & Fixes Diesel Engine Technology
No new posts A3 - AHF: Humming at 2000 RPM Diesel Engine Technology
No new posts Strange humming noise on ASZ TDI PD engine Diesel Engine Technology
