Caddy (AEY) is now starting again!!
Paule
Post14-07-2002, 21:02    Subject: Caddy (AEY) is now starting again!! Quote
icon_biggrin.gif icon_lol.gif icon_biggrin.gif icon_lol.gif icon_eek.gif icon_biggrin.gif icon_razz.gif icon_biggrin.gif
Hello everyone
Now it's working again, it was the G28 speed sensor.
Diagnostic device repeatedly failed after short operation.
this error.
However, I assumed that the G28 was functioning correctly, because I had tested it in a Vento, so I ignored this error.
Well, it's a problem. IF THE G-28 FAILS, THE NEEDLE DRIVE PROVIDER TAKES OVER THIS TASK, SO IF YOU HAVE THE G-28
THE PIN PRINGER IS BROKEN!!!
SEE VAG ERROR DIAGNOSTIC CATALOG
I am glad to have found this page.
Thank you for all the contributions, help, and links.
Definitely recommend
Post14-07-2002, 22:01    Subject: Caddy (AEY) is now starting again!! Quote
Post15-07-2002, 18:43    Subject: Direct measurement values at the G28? Quote
Have you checked the faulty G28 with a multimeter?
He should have a 1 - 1.5 kOhm resistor between pin 1 and 2.
I would be interested to know how a "completely broken" item is measured.
Paule
Post17-07-2002, 14:39    Subject: Caddy (AEY) is now starting again!! Quote
I measured the faulty device, and it had 1.2V on pin 1+2.
The Vento was running with it, but I think it's only because of the needle hub.
But it could also be that it was the wiring that was the problem, because the new G-28 had a different connector. I poked the wires with two paper clips at the top of the STG and then attached them with Krocks.
Yes, I have checked the cables for continuity and short circuits. Everything was fine.
Paule
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heckklappe VW Caddy Mj.2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN won't start Diesel Engine Technology
This topic is locked, you cannot edit or reply. Engine Won't Start, AFN Issue? Diesel Engine Technology
No new posts Audi A4 won't start On-Board Diagnostics (OBD)
No new posts Golf IV TDI AJM Notprogramm, Springt fast nimmer an On-Board Diagnostics (OBD)
