Golf IV Climatronic blowing only warm air
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
supi
Post25-05-2004, 11:47    Subject: Golf IV Climatronic blowing only warm air Quote
A colleague's Golf IV is only blowing warm air.
Read data using a VAG-COM Comfort control unit. No error codes.
The antseuer signal for the magnetic coupling appears to be OK.
However, the evaporator temperature remains constant at -53 degrees.
The value is not plausible.
Where is this sensor located?
Has anyone ever experienced (or fixed) this issue before?
I am grateful for any further information.
Julian
Post25-05-2004, 13:54    Subject: Golf IV Climatronic blowing only warm air Quote
I would say it's reading incorrectly... Channels that are not in use usually display -53°C.
You also need to read the climate control module, not the comfort control module. Does the Climadisplay flash multiple times when it's turned on?
supi
Post25-05-2004, 16:55    Subject: Golf IV Climatronic blowing only warm air Quote
I would say it was misread...
@Julian
Thank you for your interest. It's unlikely that it was misread. However.
Incorrectly translated (08 Auto HVAC). VAG-COM is quite ingenious. It was definitely...
the vaporizer temperature (something with 'panel... g193', or similar).
Display blinking <=> error code. No, no blinking lights, no error codes.
I recommended to my colleague to install or uninstall his Clima-STG.
Remove the glove compartment and check the wiring. What do you think?
Julian
Post25-05-2004, 19:02    Subject: Golf IV Climatronic blowing only warm air Quote
Unnecessary... the 'brilliant' VAG-COM offers an actuator diagnosis. It's probably the temperature flap motor, just like in many other Golf 4s.
Gremlin
Post26-05-2004, 8:39    Subject: Golf IV Climatronic blowing only warm air Quote
That doesn't explain the -53° though...
I would put the clima in diagnostic mode (CTRL-ALT-DEL icon_wink.gif) and then read channel 40.
The label files (if they even exist) are extremely dangerous when it comes to the Climatronic system.
If channel 40 also displays -53°, then some skillful craftsmanship is probably required.
CU Gremlin.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Doku Sharan 7M8, Climatronic defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Leerlaufverbrauch Kalt-Warm MFA Diesel Engine Technology
No new posts Grundeinstellung J68 Stellmotor für Heizung Warm/Kalt? On-Board Diagnostics (OBD)
No new posts Climatronic VW Golf IV Transmission, Chassis, Body & Interior
No new posts Climatronic VW Golf IV, Kühlmitteltemperatur On-Board Diagnostics (OBD)
