AHF vs. ALZ: Key Differences Explained
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post28-05-2004, 15:41    Subject: AHF vs. ALZ: Key Differences Explained Quote
Hi!
Since I am a proud owner of an 81 kW AHF engine (including the vehicle icon_biggrin.gif), I am curious about the actual technical differences between it and the 96 kW ALZ engine. Since both are 1.9L engines, and my AHF already has a VTG (Variable Turbine Geometry) and an oil cooler (LLK), the extra power can probably only be achieved through larger injectors and a modified engine management system. Or am I mistaken? Is it possible to bring the AHF up to the 96 kW power output without major modifications?
Thank you for the answers.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Translated on 25-10-2026, 11:38.
Back to top Profile PM Email
Post28-05-2004, 15:49    Subject: AHF vs. ALZ: Key Differences Explained Quote
To the best of my knowledge, the ALZ is a 1.6L engine with 75 horsepower. In my opinion, there is also no 1.9L TDI engine with a distributor injection pump and 96 kW.
Perhaps you are referring to the ASZ engine, which does not use a distributor injection pump, but instead uses pump-nozzle elements.
96kW in the AHF (presumably referring to a specific vehicle or system) is not a problem (you can install a tuning box or chip).
Translated on 25-10-2026, 11:39.
wbuchi82
Post28-05-2004, 17:10    Subject: AHF vs. ALZ: Key Differences Explained Quote
Thank you, Rainer!
Yes, of course, I meant the ASZ. icon_redface.gif If it's a PD engine, then all of that becomes irrelevant. icon_lol.gif I wasn't planning on converting to a pump-injector system just yet.
Translated on 25-10-2026, 11:41.
No new posts 1Z vs. ALE: Key Differences Explained Diesel Engine Technology
No new posts Differences between AFN and AHF? Diesel Engine Technology
No new posts Module Heater Differences: A Comparison Guide Transmission, Chassis, Body & Interior
No new posts TDI vs. TDI PD: Key Differences Explained Diesel Engine Technology
