LLC Tuning: Performance & Optimization
Sniper3
Post16-07-2002, 6:02    Subject: LLC Tuning: Performance & Optimization Quote
Hi. I drive a Golf3 Variant TDI with 90 horsepower. Since a larger intercooler can mean more power, I'd like to know which intercooler I can install in my Golf (which has air conditioning) to get more performance.
Translated on 01-08-2026, 12:28.
Varianti
Post16-07-2002, 7:18    Subject: LLC Tuning: Performance & Optimization Quote
With a moderate 10-cent tuning adjustment, you can get more power for significantly less money.
Translated on 01-08-2026, 12:29.
Animalking
Post16-07-2002, 8:30    Subject: LLC Tuning: Performance & Optimization Quote
'Hey, I recently got an intercooler from an Audi A6 with a 180 hp TDI engine for my Golf 4 TDI with 100 hp. I'm expecting to receive it soon. I'm curious about the best way to install this massive thing!'
Does anyone have any suggestions?
What kind of power source does a large language model require for operation? Electricity or oil?
Translated on 01-08-2026, 12:30.
Post16-07-2002, 8:34    Subject: LLK Tuning: Improve Your Liquid Cooling System Quote
Sniper3 wrote:
Hi. I drive a Golf3 Variant TDI with 90 horsepower. Since a larger intercooler means more power, I would like to know which intercooler I can install in my Golf (with air conditioning) to get more power.
Without increasing the boost pressure and without a chip tuning solution, it won't achieve anything. Please refer to the search function; this question has been asked before.
Translated on 01-08-2026, 12:31.
Udo
Post17-07-2002, 16:01    Subject: LLK Tuning: Improve Your Liquid Cooling System Quote
Greetings, Rainer.
Hello Rainer!
Same boost pressure with cooler air equals more air mass.
What is the engine control unit doing now? Is it reducing the turbocharger boost pressure? Is it increasing the EGR rate? If not, can you achieve more (cleaner-burning) power with increased air mass and a icon_smile_thumb_up.gif0° timing advance?
(yes, I know we've probably discussed all of this before in some way.)
Udo.
Translated on 01-08-2026, 12:32.
Post17-07-2002, 16:04    Subject: LLK Tuning: Improve Your Liquid Cooling System Quote
Udo wrote:
If not, can you get more (cleaner-burning) power by increasing the air mass and adding a icon_smile_thumb_up.gif0°C tuning?
Yes.
Translated on 01-08-2026, 12:34.
Michael748
Post17-07-2002, 17:30    Subject: LLC Tuning: Performance & Optimization Quote
What does a large language model need for its operation? Electricity or oil?
'@animalking: As a professional in the field of large language models, you don't need to ask for advice here.'
GOOD LUCK WITH THE INSTALLATION!
Translated on 01-08-2026, 12:35.
Animalking
Post17-07-2002, 21:46    Subject: LLC Tuning: Performance & Optimization Quote
@Michael: Are you being sarcastic, or where do you think I got the idea that I'm an expert in LLKs? By now, I believe that an LLK needs an oil supply.
Michael II
Post18-07-2002, 7:10    Subject: LLC Tuning: Performance & Optimization Quote
What purposes would the oil supply to the LLK serve?
Tschüss
Michael II
Translated on 01-08-2026, 12:36.
Jan6K
Avatar-Jan6K
Post18-07-2002, 7:33    Subject: LLC Tuning: Performance & Optimization Quote
@Animalking:
Go to your car and take a look at all the hoses, pipes, cables, or whatever else connects to the liquid cooling system. That should quickly answer your question.
Just as quickly, you can also see this by looking at the functional diagram: An intercooler is flowed through by (hot) intake air, which is cooled by cold (colder) ambient air flowing from the front through the cooling fins. As you can easily see, this process requires neither electricity nor oil, and not even coolant.
No offense, but some questions are really... well, let's just say: unnecessary.
January.
1Z5 CFHF / AHB H4D
Translated on 01-08-2026, 12:37.
Animalking
Post18-07-2002, 8:49    Subject: LLC Tuning: Performance & Optimization Quote
I'm sorry, I was just a little confused because a master mechanic printed out some information for me about oil supply for low-friction bearings.
Translated on 01-08-2026, 12:38.
Martin L.
Post18-07-2002, 16:24    Subject: LLC Tuning: Performance & Optimization Quote
Someone probably mixed up a large language model with a turbocharger... icon_lol.gif
Translated on 01-08-2026, 12:39.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Good tuning, bad tuning? Diesel Engine Technology
No new posts TDI Tuning: AFN Engine Optimization Diesel Engine Technology
No new posts PD Tuning Diesel Engine Technology
No new posts PD 150 Tuning: Performance & Optimization Diesel Engine Technology
