Where do you check the automatic transmission fluid level on a Volkswagen Golf 4 with a 77 kW engine and a 5-speed Tiptronic transmission? And where do you add more if necessary?
I probably made a mistake
. I wanted to change the engine oil and grabbed the wrong screw (a 27mm hex bolt, straight down from underneath, the only one that was easily accessible). In any case, what came out wasn't black engine oil, but a reddish-brown, verschandeln oil. I didn't move the vehicle as a precaution.
Please respond quickly; I need the car back soon.
Thank you in advance.
Martin.
