2,5TDI AEL ist sehr träge | Posts 16+
Go to page: Previous  1, 2
Tuppie
Post03-06-2004, 0:08    Subject: Quote
@TDI-Quattro
I've modified my DZT table with your data (49 km/h = 1500 rpm, 12.8 seconds). If those values are accurate, then your AEL tolerance of +/- zero is correct. However, I don't know if the DZT test can be adjusted to use the 4th gear. It would be better to run the test in 3rd gear; that comparison would also be interesting for me.
Good night.
Tuppie.
Translated on 02-08-2026, 16:52.
TDI-Quattro
Post04-06-2004, 16:21    Subject: Quote
Hi, I took it for a test drive yesterday evening. Initially, with the AC on, it took 6.4 seconds to complete the test in 3rd gear. Without the AC, over three attempts, the times were 5.8 / 6.0 / 6.1 seconds.
At 2000 RPM in 3rd gear, the on-board computer indicated a speed of 45 km/h!
The values seem to be okay.
Thomas.
Translated on 02-08-2026, 16:54.
Tuppie
Post04-06-2004, 16:31    Subject: Quote
@TDI-Quattro
What are you complaining about with those values? Do you happen to have your transmission MKB code handy? Is that also an ARX 6-speed? I don't think so; based on your stated RPM/speed ratio, yours seems to be shorter geared.
Tuppie.
Translated on 02-08-2026, 16:55.
TDI-Quattro
Post04-06-2004, 19:20    Subject: Quote
Hey, I don't have the GKB data available right now. But even in the lower gears (2nd and 3rd), it pulls strongly, no question about that. Personally, I find it a bit sluggish in 4th, 5th, and 6th, even though the values seem correct. I had higher expectations initially, but I've gotten used to it now. The original post is also quite a few weeks old! I've also developed a different riding style lately, more cruising than speeding. It's still fun with this big bike!
Stay relaxed.
Thomas.
Translated on 02-08-2026, 16:56.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts VW Passat 1.9 TDI: Slow & Weak? Fix with Log! Diesel Engine Technology
No new posts Slow-reacting heated seats Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Boost Lag & Soot: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Heated Seats: Slow to Warm Up? Diesel Engine Technology
