Passat 3BG: Rear Door Unlock Problem?
joergs
Post05-06-2004, 14:27    Subject: Passat 3BG: Rear Door Unlock Problem? Quote
I'm having a problem with my Passat, model year 2001.
'The rear passenger side door is stuck and won't open. It seems like the central locking system is no longer releasing the lock. The comfort control system shows an error: 'door contact short circuit to ground,' and the CAN gateway indicates 'no communication with the rear right door.' I just removed the interior paneling, but I can't see anything and it's hard to reach. Is there a trick to get the door open, at least enough to remove the locking mechanism?'
Translated on 29-08-2026, 20:19.
christians
Post05-06-2004, 19:07    Subject: Passat 3BG: Rear Door Unlock Problem? Quote
If no one knows exactly what to do, you probably should take the other door apart and try to reach the crucial lever with a wire.
Gruß Christian
Translated on 29-08-2026, 20:20.
joergs
Post11-06-2004, 13:11    Subject: Passat 3BG: Rear Door Unlock Problem? Quote
so dala,
(This appears to be a single word or phrase with no clear meaning without context. It's difficult to translate without knowing what it refers to.)
The door is open... icon_razz.gif The cause of all this trouble was the failure of the CAN gateway in the rear door. This caused the central locking system to be locked, preventing the lock from being released... Once again, a marvel of German engineering. What happens in such a case, if the comfort control system is working and the entire car is locked, and you have an accident? Good morning...
Translated on 29-08-2026, 20:21.
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Rear Door Handle - Replacement Transmission, Chassis, Body & Interior
No new posts Replacing rear brake discs on a G3 - difficult? Transmission, Chassis, Body & Interior
No new posts Worn Inner Tire: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Radio installation T6, Rear speaker retrofit for van Electrical Systems, Vehicle Electronics, Multimedia
