Replace Door Seal: DIY Guide & Tips
FrankN
Post16-05-2004, 23:13    Subject: Replace Door Seal: DIY Guide & Tips Quote
The rubber seal on the rear right door of my Golf IV is torn.
'Can anyone tell me if any special tools are needed to replace the seal, or what the best way to proceed is?'
Thank you in advance.
Frank.
Translated on 30-08-2026, 5:32.
Post17-05-2004, 8:59    Subject: Replace Door Seal: DIY Guide & Tips Quote
Which one are you referring to, the one with the continuous roof (3-door or 5-door)?
Okay, I once replaced the inner door seal on a Passat (which doesn't have a roof trim seal). It was relatively straightforward. It did take quite a while, but I didn't feel like I needed any special tools, although I can't rule out that there might be some available.
FrankN
Post17-05-2004, 20:18    Subject: Replace Door Seal: DIY Guide & Tips Quote
It's a 5-door model. I'm referring to the internal rubber seal.
I noticed that the casting has a metal insert.
Therefore, my question is whether you need any special tools for that, or if it just requires a lot of finger strength.
Frank.
Translated on 30-08-2026, 5:33.
klopfer
2007 Audi A4 Avant
Post27-05-2004, 17:36    Subject: Replace Door Seal: DIY Guide & Tips Quote
Hello Frank,
I have an Audi, and with it, you just need enough strength in your fingers. A rubber mallet might be helpful for inserting the new seal, as you can gently tap it into place with it.
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 30-08-2026, 5:34.
FrankN
Post22-06-2004, 17:00    Subject: Replace Door Seal: DIY Guide & Tips Quote
I changed the gasket today. At first, I thought they had sold me the wrong gasket because it was much too long.
I then called my VW dealer. He told me that the seal needs to be inserted in a 'wave-like' manner. The waves can then be easily tapped into place with a rubber mallet. This compresses the seal.
Once you know that, the matter is relatively simple.
Frank.
Translated on 30-08-2026, 5:35.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts Change Air Filter? [DIY Guide] Diesel Engine Technology
No new posts Water Pump Replacement 1Z Diesel Engine Technology
No new posts ESP Replacement: Simmering Guide & Tips Diesel Engine Technology
