VW Turbodiesel from Golf 2, salvageable or beyond repair???
The Driver
Post26-06-2004, 13:45    Subject: VW Turbodiesel from Golf 2, salvageable or beyond repair??? Quote
hello,
I'm new here! Here are some information about my child who is struggling:
I bought a Caddy 1. One of the previous owners had installed a Golf 2 turbodiesel engine (JR 1.6 with 69PS).
He didn't run perfectly from the beginning. He also repeatedly refused to start.
then he was tied to another car and towed, when towing, he also immediately came to the coupling when releasing.
If I start it when it's warm, I usually need to try twice. Sometimes, however, it just doesn't work at all.
Finally, he also didn't want to [ACTION] even when he had sufficient pre-heating time.
What could be the cause? I'm a pretty new diesel engine user. But, as far as I know, there's nothing wrong with the engine itself.
I checked the light bulbs, they seem to be okay.
If I disconnect the diesel lines to the fuel injectors, will all 4 diesels start?
A garage (a rather shady one) measured the compression, and told me the following values: 8.5/10.5/19 bar. The 4th cylinder was not measured, but they immediately wanted to replace the cylinder head and new piston rings, etc. All in all, a repair costing more than 1000 euros!!!
I think they were just trying to make a quick buck. Because the diesel engine still runs (if it feels like it), and it definitely goes through, even when being towed! So, the values can't be that bad. If the compression values are that low, no diesel engine in the world can run like that, right?
I would be very grateful for contributions that are truly helpful!
WarLord
Post26-06-2004, 14:00    Subject: VW Turbodiesel from Golf 2, salvageable or beyond repair??? Quote
Hm, so the compression values are already beyond good and bad. I would like to have them checked again at another workshop.
Best regards, WarLord
The Driver
Post27-06-2004, 21:00    Subject: VW Turbodiesel from Golf 2, salvageable or beyond repair??? Quote
but it's not so intoxicating here the resonance!
Post27-06-2004, 21:20    Subject: VW Turbodiesel from Golf 2, salvageable or beyond repair??? Quote
If you can't interpret the compression values, that's your personal misfortune.
Either you believe it, then you must investigate what is leaking: valves or piston rings.
If you don't believe it, you'll just have to get it measured somewhere else.
But hasn't Warlord also said so? So, what do you want?
No new posts Doku Golf 1J bis 09/2000, Schnapp- oder Klappgeräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 5, Fahrzeug zieht nach links oder rechts Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Torque Arm: Alternatives or Best Choice? Transmission, Chassis, Body & Interior
No new posts Turbodefekt: Causes, Symptoms, and Repair:( Diesel Engine Technology
No new posts Ruckeln durch NHG - oder doch nicht?! Diesel Engine Technology
No new posts Weak acceleration???? or is it normal???? Diesel Engine Technology
