Weini Guest
01-07-2004, 18:46 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
Hello!
Today, I replaced the three fuel injectors in my 12-year-old Audi 80 TDI (1Z), and I was quite surprised when I examined the injectors.
The engine was still running perfectly and it wasn't smoking, but I can't imagine that injector nozzles that are so coked up would still produce a good spray pattern  .
Well, everyone can form their own opinion about whether it's better to replace those good things after all.
Have fun trying it out!
Regards - Weini
http://www.geocities.com/weini.geo/tdi/tdi.html
| Description: |
| File size: |
46.91 KB |
| Viewed: |
4785 times |
Translated on 23-10-2026, 6:59.
Julian Guest
01-07-2004, 18:51 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
The link is not working...
Sorry, this site is temporarily unavailable!
Translated on 23-10-2026, 7:00.
xxl Guest
01-07-2004, 19:52 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
'That's normal. When there's high traffic, Yahoo sometimes turns the page off and on. There's a maximum number of visits allowed per hour.'
Try it again later.
Best,
Alex
schnappi Guest
01-07-2004, 20:08 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
When should the nozzles normally be replaced?
Translated on 23-10-2026, 7:01.
daytrader Guest
01-07-2004, 20:13 Subject: Fuel Injectors at 239,000 km: Picture |
they will probably look like mine, which currently have 243,000 km.
joergs Guest
01-07-2004, 20:28 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
Two of them look like they've dripped.
Translated on 23-10-2026, 7:02.
Gremlin Guest
02-07-2004, 8:56 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
which I consider to be more likely the cause:
with chip tuning from ********
Over-injection can lead to thermal problems.
Nevertheless, fuel injectors are wear-and-tear parts that should be regularly checked.
CU Gremlin.
Weini Guest
02-07-2004, 9:34 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
I can't imagine that it's related to the chip tuning.  I've had the chip installed for 210,000 km now, and I'm completely satisfied with it.
Yes - nozzles are definitely wear parts!. I completely agree with that, and replacing them after a certain amount of use (as can be seen) is definitely recommended! }
Weini
Translated on 23-10-2026, 7:03.
Rudi Guest
02-07-2004, 10:46 Subject: Fuel Injectors at 239,000 km: Photo. |
Today, I replaced the 3 fuel injectors in my Audi 80 TDI (1Z), which is now 12 years old...
Why only three???
Do yourself (or your engine) a favor and replace the fourth one too.
Otherwise, these are nice pictures for the 'Why should I do this or that on a TDI?' collection. They fit well with the AGR pictures.
Best regards, Rudi.
Translated on 23-10-2026, 7:04.
Weini Guest
02-07-2004, 13:29 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
Why only three????
Because the needle lifter failed about a year ago (it was making strong, jerky movements) and has already been replaced.
Visually, it didn't look nearly as bad as the three nozzles do now.
Interestingly, the NHG (noise, vibration, and harshness) and the clutch master cylinder were the ONLY  parts that have failed so far. We've had 1 exhaust pipe, 1 water pump, 1 clutch, 1 wheel bearing, etc. And that's after 12 years!
I'm really proud of my car.
Translated on 23-10-2026, 7:06.
Obermeister Guest
02-07-2004, 17:23 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
I once read that someone cleaned their fuel injectors in an ultrasonic cleaner.
Will it make a difference?
Dripping nozzles certainly won't fix the problem, but what about carbon buildup?
Does anyone have information about the cost-benefit analysis?
Translated on 23-10-2026, 7:07.
joergs Guest
02-07-2004, 17:28 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
@obermeister
'The ultrasonic cleaner might dissolve the Siff, but with that kind of mileage, the springs will be worn out, the drill bits will lose their sharpness, and so on. At that point, the ultrasonic cleaner won't help anymore...'
Translated on 23-10-2026, 7:08.
D. Guest
02-07-2004, 18:06 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
I've been thinking about it for a long time. But, as you also mentioned, everything is still working perfectly: no smoke, low fuel consumption, and good performance.
Have you noticed any tangible changes since the switch?
Joohn Guest
03-07-2004, 13:48 Subject: Fuel Injectors: 239,000 km / 148,000 miles |
What kind of gasoline do you usually use? Aral, Shell, Esso, etc.?
Translated on 23-10-2026, 7:09.
