GRA: Only 3/4 Throttle? No Full Throttle
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
el_diesel
Post30-06-2004, 10:42    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
hello,
My Golf 4 TDI (90 hp, manufactured in 2000) only runs with 3/4 throttle.
'When I drive with the accelerator pedal, it reaches 180 km/h. However, when I activate the cruise control, it automatically reduces the speed to 160 km/h. It should maintain the full throttle setting.'
'Thank you in advance!'
Translated on 24-10-2026, 10:16.
Post30-06-2004, 14:45    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
Funny.
My G3 TDI (1Z, 90 hp) also reaches 180 km/h with the GRA (presumably referring to a speed limiter or governor).
I even saw while logging that the GRA (presumably referring to the throttle or accelerator) could actually deliver more power (higher throttle demand) than I could ever achieve with my foot.
The fact that it doesn't simply turn off, but instead regulates to 160, suggests a kind of safety mechanism.
Whether that is true or not is likely to be difficult to determine.
Translated on 24-10-2026, 10:18.
el_diesel
Post30-06-2004, 15:11    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
I had them installed by a Volkswagen dealership.
No, when I had it retrofitted, it worked perfectly, and the cruise control also worked at 180 km/h.
It has only been running at 160 km/h for about 3 months.
Best regards.
Translated on 24-10-2026, 10:19.
Jan6K
Avatar-Jan6K
Post30-06-2004, 16:06    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
My ASV (2001) easily reaches a speed of 190 km/h with cruise control enabled.
"@Dieselmartin: That aligns with my observations. I've always felt that the engine accelerates more strongly around 2000 RPM when you apply gas by holding the RES button, compared to using the accelerator pedal. In my opinion, it seems to revert back to normal at higher RPMs... otherwise, it would be the perfect "tuning" for the DZR test."
@el-diesel: What happens if you're going 160 km/h and then press the accelerator (+, usually meaning full throttle)?
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-10-2026, 10:20.
el_diesel
Post30-06-2004, 16:17    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
Then it's like when I press the pedal.
If I let go, it falls back down.
As I said, after the installation, it worked perfectly.
Translated on 24-10-2026, 10:21.
Jan6K
Avatar-Jan6K
Post30-06-2004, 21:20    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
Hmm... could it be that some implausible signal is being received, causing the GRA (presumably a system or device) to temporarily shut down, and only reactivating below 160 (presumably a threshold value)?
While my understanding of this control system makes it seem unlikely, you could check the measurement blocks in the engine control module (ECM) if you have VAGCOM. If there's anything unusual about the speed signal, that might be the reason.
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-10-2026, 10:22.
el_diesel
Post30-06-2004, 21:36    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
Is it possible to reset or adjust the GRA (Ground Reference Altitude)?
The error memory doesn't show anything.
Translated on 24-10-2026, 10:23.
Jan6K
Avatar-Jan6K
Post01-07-2004, 7:13    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
IMO = in my opinion.
AFAIK = as far as I know.
To my knowledge, there is no reset function for the GRA (presumably a specific system or module). The error memory doesn't necessarily have to be the same. Simply observe (or have someone observe) the measured value blocks while driving.
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-10-2026, 10:24.
el_diesel
Post01-07-2004, 8:45    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
but it can be enabled and disabled - so, a reset!
I'll give it a try.
Translated on 24-10-2026, 10:25.
Post01-07-2004, 22:05    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
@ Jan
No, it didn't actually accelerate any faster. The values in the log were just higher.
My baby TDI actually starts to engage the torque limiter at just 35.2 mg/H icon_sad.gif(((.
With Mitm, I can achieve a maximum of 42 mg (a dream scenario). The GRA (gravitational acceleration) was significantly higher, exceeding 46.
Jan6K
Avatar-Jan6K
Post01-07-2004, 22:10    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
@MartinViewing profile: Martin: I should probably check the logs to see how it compares to ASV - I almost suspect that it's a slightly higher value.
@el-diesel: ??? RES = Resume = "Resumption" or "Summary".
If you want to reset the control unit, forget about it. That's not possible with our MSG systems.
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-10-2026, 10:26.
el_diesel
Post05-07-2004, 14:13    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
It was the LMM.
I only had 450 left. The new one has 750. Is that okay?
Translated on 24-10-2026, 10:27.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post05-07-2004, 16:48    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
el_diesel wrote:
It was the LMM.
It's new now, and the temperature sensor is working again... icon_biggrin.gif
LOL. icon_lol.gif Someone didn't notice that, so the engine doesn't pull as much anymore.
B.Eng (FH) u. KFZ Meister
Translated on 24-10-2026, 10:28.
gerbi
Post05-07-2004, 17:43    Subject: GRA: Only 3/4 Throttle? No Full Throttle Quote
The Golf GTIs look good again in the rearview mirror, don't they? icon_wink.gif
Translated on 24-10-2026, 10:29.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHF 81 kW Machine: Who Still Uses It? Diesel Engine Technology
No new posts Polo 9N 100PS TDI: Owners, share your experience! Diesel Engine Technology
No new posts Wastegate Valve Golf 4: Malfunctioning? Transmission, Chassis, Body & Interior
No new posts Passat B4 Window Regulator: Automatic Up? Transmission, Chassis, Body & Interior
