EU4 Polo 9N: Conversion with Modified Catalytic Converters?
Post04-07-2004, 20:02    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
The 96 kW Polo is now available as an EU4-compliant vehicle.
The BLT engine was likely developed from the ASZ.
The hardware differences are largely similar to the 100 horsepower performance level.
AGR cooling, "throttle valve", other PDE - as far as I know.
But, strangely, all EU4 TDIs in the Polo (BAY, AXR, and BLT) also have a different turbocharger than the EU3 versions AMF, ATD, and ASZ.
Can anyone figure out why the "old" loaders are no longer good enough for EU4 icon_eek.gif icon_question.gif?
By the way, all 1.9 TDI engines in the 9N models are equipped with KKK turbochargers (instead of Garrett), only the 1.4 three-cylinder engines have Garrett turbochargers.
Translated on 03-10-2026, 12:16.
Julian
Post04-07-2004, 22:48    Subject: EU4 Conversion Polo 9N: Reloader Required? Quote
By the way, all 1.9 TDI engines in the 9N are equipped with KKK turbochargers (instead of Garrett), only the 1.4 three-cylinder engines have Garrett turbochargers.
Um, not the other way around... at least that's how it is with the A2, which has KKK turbochargers on its 3-cylinder TDIs...?
Translated on 03-10-2026, 12:18.
Olaf
Post04-07-2004, 23:36    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
The AMF in the A2 also has a Garrett turbocharger (size 15).
Olaf.
Translated on 03-10-2026, 12:19.
Back to top Profile PM Email
mcgyver2k
Post05-07-2004, 10:16    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
Could it be that they modified something on the turbine wheel to achieve a higher exhaust pressure for higher EGR rates?
01er Skoda Fabia Combi ATD
Post05-07-2004, 11:58    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
mcgyver2k wrote:
Could it be that something was changed on the turbine wheel to achieve a higher exhaust pressure for higher EGR rates?
While this would likely lead to a decrease in the overall efficiency of the system, it seems that anything can be justified in the name of environmental protection, no matter how absurd.
Post05-07-2004, 13:53    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
@ulfViewing profile: ulf:
By the way, all 1.9 TDI engines in the 9N model are equipped with KKK turbochargers (instead of Garrett).
Oh, is that why the ASZ engine in the Polo is about 2,000 euros cheaper as a replacement part than the ASZ engine in the Golf icon_wink.gif?
The prices for new parts range from approximately 5,200 to 7,200 euros.
Translated on 03-10-2026, 12:20.
Post05-07-2004, 16:19    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
Roger wrote:
Oh, is the ASZ engine in the Polo therefore about 2,000 euros cheaper as a replacement part than the ASZ engine in the Golf icon_wink.gif?
The prices for new parts range from approximately 5,200 to approximately 7,200 euros ...
Translated on 03-10-2026, 12:21.
mcgyver2k
Post05-07-2004, 21:39    Subject: EU4 Polo 9N: Conversion with Modified Catalytic Converters? Quote
ulf wrote:
That would certainly lead to a deterioration in the overall efficiency of the charging system - but what nonsense is being fabricated in the name of the environment?
As emission regulations become stricter, eventually the EGR system will also be activated at full load.
Translated on 03-10-2026, 12:22.
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Noises & Sounds - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Different nozzle diameters in VNT 15 loaders? Diesel Engine Technology
No new posts Retrofit GRA for 9N SDI Polo Diesel Engine Technology
No new posts Polo 9N3: EDC16 ECU Compatibility? On-Board Diagnostics (OBD)
No new posts Polo WRC Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
