Audi A3 problems with engine temperature!
operator
Post06-07-2004, 19:54    Subject: Audi A3 problems with engine temperature! Quote
Hello everyone!
As you can see, I'm new here!
Yesterday, I browsed through the posts in the car forum as a guest and repeatedly came across statements saying that this problem is not known to occur in the Audi A3.
Audi A3, 1.9L engine, 90 horsepower, manufactured in 1997.
The engine reaches 100 degrees Celsius and the warning sound goes off: coolant level is okay, thermostat has already been replaced. So, the problem is the water pump!! In this engine type, the impeller of the water pump is made of plastic and can detach from the shaft! My tip: Since the timing belt needs to be replaced at 60,000 km for this model, have the water pump checked at the same time. Otherwise, you might end up in a situation like mine, where you'll have the same amount of work at 70,000 km as you would with just replacing the timing belt, and that will be expensive!
operator
Translated on 17-07-2026, 15:32.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post06-07-2004, 20:55    Subject: Audi A3 problems with engine temperature! Quote
On the AFN and 1Z engines, the water pump is not driven by the timing belt.
You will likely have an AHU motor, and unfortunately, this plastic impeller often breaks.
Whoever doesn't replace the water pump at 90,000 km is to blame themselves. icon_cool.gif
B.Eng (FH) u. KFZ Meister
Translated on 17-07-2026, 15:34.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 2.5 probleme On-Board Diagnostics (OBD)
No new posts Motor Temperature for TDI Tuning Diesel Engine Technology
No new posts White smoke at medium engine temperature (in a German-mad... Diesel Engine Technology
No new posts Passat 3B: Engine Overheating & Temperature Issues Diesel Engine Technology
