Rear-wheel drive VW Passat, manufactured in 1998
ttt
Post11-07-2004, 0:41    Subject: Rear-wheel drive VW Passat, manufactured in 1998 Quote
Can someone tell me how the rear wiper is controlled (voltage pulse or switching to ground)?
My windshield wiper is broken and no longer works. The motor itself functions, but the control unit is heavily corroded due to water damage.
Four wires connect to the wiper motor (terminal 31, terminal 15, INT, and ground). Since only surface-mount components are on the circuit board, I'm wondering if these components are available for individual purchase.
Thank you for your help!
Translated on 18-07-2026, 13:39.
Madness
Post12-07-2004, 19:11    Subject: Rear-wheel drive VW Passat, manufactured in 1998 Quote
Is that a Passat 3B or what?
Then the wiper motor is only available as a complete unit.
Translated on 18-07-2026, 13:40.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Schwungrad Passat TDI BJ98 AFN. Diesel Engine Technology
No new posts Heckwischer A6: The Ultimate Guide Transmission, Chassis, Body & Interior
No new posts Ford Galaxy BJ98 Diesel Engine Technology
This topic is locked, you cannot edit or reply. A6 TDI 2,5L 110kw BJ98 ESP defekt Diesel Engine Technology
