Hello everyone, I'm new here. I've spent half the day reading technical articles, learned a lot, but haven't been able to connect much of it to my car...
Here's a little background:
I drive a Passat 3B TDI, manufactured in 1998, with a 1.9L TDI engine (90 hp). The engine code is AHU. I've owned the car since January, and the previous owner had installed a 'tuning box,' which I decided to leave in for the winter with the intention of removing it in the spring.
In May, I started thinking about getting a 'proper' chip to achieve my performance goals in the most engine-friendly way! Discouraged by various offers from different companies, ranging from Digitec to garage tuners, I considered the idea of first 'revving up' the existing 'fake' chip before getting rid of it...
I did what I was told and turned the potentiometer from approximately the middle position to about 3/4, just to see what would happen! I then drove a distance of almost 1 kilometer. The acceleration was really good, and then, just outside the town, I revved the engine in the second gear up to 3,800 RPM, when there was a sudden loss of power: the engine seemed to 'cut out,' but it kept running, although I lifted my foot off the accelerator! For the remaining 200 meters, I didn't see anything in the rearview mirror
. After that, I turned the potentiometer back down...
My initial amateur diagnosis was straightforward: too much diesel being injected, which wasn't igniting... The problem with that: ever since, the car has been constantly producing black smoke, especially when starting up and running for a short time (like a chimney).
'The P-box is now installed, and a 30 HP chip from In-Motion-Tuning has been fitted (carefully soldered in), but I haven't noticed much of a difference. It's still producing black smoke! After a faulty valve cover gasket that caused oil loss of nearly half a liter every 500 km, I've been going from one mechanic to another, and from one VW dealer to another, since the beginning of June.'
In the meantime, the LMM (mass airflow sensor) has been replaced, the turbocharger has been checked (no oil in the coolant!!!), the intercooler system has been checked for leaks, the engine control unit has been temporarily replaced, the fuel injection pump's start of injection has been checked, and much more. The result is: the car is still producing excessive soot! According to the workshop, the last resort for troubleshooting would be to replace the fuel injection pump, but this cannot be done as a test. Otherwise, we are all, including me, stuck in the 'valley of the clueless'
'The car definitely lacks power. It mainly produces black smoke at lower RPMs under load (it's worst when driving uphill in a 30 km/h zone..., but I don't see anything on the highway...). And recently, I've been experiencing a 'jerky start' (it doesn't accelerate, it just jerks), but only occasionally!'
Could it really be the pump? Could it have something to do with the sports exhaust system?
I am grateful for any advice!
whitelife
