ALE Nozzles: Size, Pressure, and Specs
Post28-07-2004, 9:53    Subject: ALE Nozzles: Size, Pressure, and Specs Quote
Hi.
To the best of my knowledge, the ALE is the Euro3-1Z/AHU model.
The two older ones have 184 my / 190 bar Dueses.
What does the ALE have?
The background is that I have an MSA12 (021AF) in the 1Z, and now I have a MAS15 here (021HD - only used in the ALE).
If the ALE 220 bar nozzles are used, the injection start timing will be different (thanks, Rudi), and it likely won't be compatible with my old 190 bar nozzles.
Translated on 07-09-2026, 17:18.
Rudi
Post28-07-2004, 11:02    Subject: ALE Nozzles: Size, Pressure, and Specs Quote
Hi Martin,
It's possible that you misunderstood me there.
It will work with your nozzles! These are the 'spray start' nozzles.
I already sent that to you. They're not that different.
The dynamic injection start may need to be adjusted.
(which was not necessary after my conversion to .216 / 220 bar).
Best regards, Rudi.
Translated on 07-09-2026, 17:20.
No new posts 190 bar Nozzles: Upgrade to 220 bar Nozzles Diesel Engine Technology
No new posts Injector Nozzle Size 1Z: Diameter Guide Diesel Engine Technology
No new posts Piston Slap: High-Pressure vs. Bore Diameter Diesel Engine Technology
No new posts Fuel Injector Nozzle Size 0.216mm - 2.5L Diesel Engine Technology
