Fuel station - fuel is coming out
Nelo
Post29-07-2004, 17:42    Subject: Fuel station - fuel is coming out Quote
Hello!
I'm from Slovenia and I recently started driving an A4 TDI (11/01, 74 kW), and I'm having a strange problem.
Fuel is leaking from the gas cap and it's clearly visible on the fender and bumper. I initially thought I might have overfilled the tank, but even after refueling, it was only half full. Then, after a short highway drive at approximately 150-160 km/h, it was the same again.
I think there might be pressure building up in the storage tank, or perhaps a valve is blocked.
Has anyone perhaps had a similar experience?
Nelo.
Translated on 03-07-2026, 21:58.
Post29-07-2004, 19:23    Subject: Fuel station - fuel is coming out Quote
"Welcome to our community, the first Slovenian diesel mechanic member!"
I suspect the seal in your fuel tank cap is simply defective. --> Replace the fuel tank cap and that should fix it.
Guste.
Translated on 03-07-2026, 21:59.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air bubbles in diesel fuel, faulty fuel tank? Diesel Engine Technology
No new posts Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Diesel Engine Technology
No new posts Audi A4 B7: Seat Occupancy Disable Coding On-Board Diagnostics (OBD)
No new posts Erwin Kicks Out Private Individuals? Dieselschrauber Bar
