Welcher Motor im Golf IV !? | Posts 16+
Go to page: Previous  1, 2
joergs
Post04-08-2004, 21:53    Subject: Quote
*lol* The car has only been down for 2 hours. I'm still drinking my (christening/baptismal) beer...
When a ship is christened, a bottle of champagne is smashed against the hull. icon_razz.gif
Translated on 10-07-2026, 20:09.
Post05-08-2004, 6:27    Subject: Quote
joergs wrote:
....wenn ein schiff getauft wird, wird ne flasche schampus gegen den rumpf gehauen........ icon_razz.gif
... Ouch, that will leave such unsightly marks on the (car) body icon_mrgreen.gif.
The ATD has a regulated EGR (Exhaust Gas Recirculation) system, but it does not have a regulated water cooling system for it.
Since the ATD is an EU3 model, I would say that it doesn't recognize a "faulty" EGR valve.
Auf ins Abenteuer Pumpe Düse...
PD engines are better than their reputation suggests. The AJM engine, which was rushed onto the market, caused a lot of problems.
Translated on 10-07-2026, 20:10.
Post05-08-2004, 6:59    Subject: Quote
Bertil wrote:
The PD engines are better than their reputation suggests. The AJM, which was rushed onto the market, caused a lot of damage.
With that hope in mind, I also bought my Polo. It seems it still pays off to not actively participate in the "banana phase" of new technologies and vehicle models (where they are maturing for customers), but rather to wait and see first icon_twisted.gif.
Tomorrow evening, we are planning to start our vacation with the help of the ASZ (presumably a local organization or service).
I'm curious to see the long-distance fuel consumption... If everything goes according to plan, I'll be offline until around the end of August.
Der ATD hat zwar eine geregelte AGR, aber keine geregelte Wasserkühlung dafür.
What do you mean by "regulated EGR"? Are you referring to the "old" principle with the mass airflow sensor (MAF) as a feedback device?
And what exactly does the German Road Traffic Regulations (StVZO) regulate regarding water cooling systems?
Is there possibly a solenoid valve somewhere that controls the water flow and is controlled by the ECU (Engine Control Unit)?
Translated on 10-07-2026, 20:12.
DocSnydor
Post05-08-2004, 7:25    Subject: Quote
Subject: Timing belt - Here's the response to my inquiry directly from Volkswagen:
Ref. No.: VW-2004/08-000821
Dear Mr. Snydor,
Thank you for your inquiry.
The timing belt replacement is required for the 1.9L / 74 kW TDI engine (engine code: ...).
For all Golf Variants with ATD engines, including models up to and including the 2003 model year, maintenance is required every 90,000 km.
vorgesehen. Gleichzeitig ist der Tausch der Spannrolle erforderlich. From
Modelljahr 2004 konnte das Intervall auf 120.000 km erhoeht werden. The
The tensioner roller needs to be replaced only every 240,000 kilometers in these models.
required.
The tenth digit of the vehicle identification number (VIN) indicates the model year.
Example 3 = 2003 or 4 = 2004.
For any further questions or suggestions, please do not hesitate to contact us.
available at any time.
i.V. Bernd Schmitter i.V. Katja Schott.
Volkswagen AG.
38436 Wolfsburg.
Phone: +49 (0) 800 8655792436
Fax: +49 (0) 221 9839 2199
Email to: [email protected]
Homepage http://www.volkswagen.de
@Ulf: I wish you a wonderful vacation!
Translated on 10-07-2026, 20:15.
Post05-08-2004, 8:08    Subject: Quote
ulf wrote:
... With that hope in mind, I also bought my Polo...
... wenn du aus dem Urlaub kommst erzähle ich dir mal mehr über den 9N .... icon_mrgreen.gif
Beautiful free spaces...
Yes, among other things.
Sitzt da womöglich irgendwo ein Magnetventil für den Wasserdurchfluß, das von der EDC angesteuert wird?
Almost got it!
Not a solenoid valve directly, but pneumatics controlled via a solenoid valve.
In the pneumatic system, where the ATD controls the shut-off valve, the AXR regulates the water cooling for the EGR (Exhaust Gas Recirculation) system. The AXR uses an electric shut-off/throttle valve for this purpose.
Translated on 10-07-2026, 20:19.
Post05-08-2004, 11:12    Subject: Quote
Bertil wrote:
... wenn du aus dem Urlaub kommst erzähle ich dir mal mehr über den 9N .... {icon_mrgreen.gif}
I'm already aware that it's somewhat unreliable... for example:
http://www.polo9n.com/phpBB2/viewtopic.php?t=5007
...and the rumbling sound from the transmission when coasting is still there, but that seems to be more of a problem with the gearbox itself.
Using pneumatics, where the ATD controls the shut-off valve, the AXR regulates the water cooling for the EGR system. For this purpose, the AXR has an electric shut-off/throttle valve.
...and possibly also the standard EGR solenoid valve including the diaphragm valve located between the intake and exhaust manifolds?
So, we need 3 actuators to cultivate the oil soot sludge in the intake manifold under precisely controlled conditions new_tomato.gif.
Translated on 10-07-2026, 20:21.
Post05-08-2004, 11:18    Subject: Quote
Nöööööö, das hab ich nicht gemeint. Du besitzt einen Kleintwagen mit der Elektronikstruktur des VW D1 (Phaeton). Die funktioniert da schon nicht besonders gut icon_eek.gif .... also ein echtes Bananenprodukt ..... icon_evil.gif
Functionally, yes, but mechanically completely different due to the altered exhaust system.
So, we need 3 actuators to cultivate the oil-soot sludge in the intake manifold under precisely controlled conditions new_tomato.gif
Wenn du meinst .... Yes.
I've never seen so little oil sludge buildup in a TDI intake manifold as I did with the AXR engine.
Translated on 10-07-2026, 20:23.
Post05-08-2004, 14:59    Subject: Quote
Bertil wrote:
You own a small car with the electronic structure of the VW D1 (Phaeton). That doesn't work very well there... icon_eek.gif... so it's really a "banana product"... icon_evil.gif
Yes, with CAN communication back and forth icon_evil.gif. . .
I just hope that at least the most obvious flaws were corrected since the start of production of the 9N in 2002 (?). And I hope that my "minimal electronics" course will help to minimize the frustration over the years.
So far, he hasn't caused any trouble...
Translated on 10-07-2026, 20:25.
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHF Engine Chip: Which is Best? Diesel Engine Technology
No new posts Which engine fits? Diesel Engine Technology
No new posts Which PD-TDI engine is recommended? Diesel Engine Technology
No new posts Ford Galaxy Engine: Which One Fits? Diesel Engine Technology
