Bieter Dohlen Guest
05-08-2004, 14:11 Subject: |
Is it okay to spray silicone oil onto the bearing of the control arm?
If that's the case! / If that's what it is!
Translated on 23-08-2026, 4:19.
wolfi_b Profi-Schrauber
05-08-2004, 14:28 Subject: |
If you're hearing a clunking sound from the front axle, it sounds to me like a worn-out joint or shock absorber. What's supposed to help with that using silicone oil?
Have you also checked if anything is loose in the engine compartment or if the engine mounts are in good condition?
Do you have lowered suspension and/or wider tires?
Of course, it puts a much higher strain on the joints! 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 23-08-2026, 4:20.
Bieter Dohlen Guest
05-08-2004, 17:21 Subject: |
No, everything's standard/stock!
And as I mentioned earlier, new stabilizer links and new tie rods have been installed! And that's after 40,000 kilometers (approximately 25,000 miles).
Translated on 23-08-2026, 4:21.
