VW Golf B4 TDI: Radio Installation Guide
Otto
Post12-08-2004, 3:11    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
Has anyone ever installed a different radio in an Audi 80 B4, model year 1993, with a TDI 1Z-BAA engine? Does anyone know the color codes for the wiring? I'm particularly interested in the antenna amplifier connection (rear window antenna), but I can't seem to find the correct cable. The wiring diagram isn't very helpful either. Is it controlled by the control unit? Is it permanently connected to the power supply, or am I just missing something?
The cable for the antenna amplifier was also present in the Passat.
Thank you for your help, Andreas.
Translated on 09-09-2026, 5:27.
wolfi_b
Post12-08-2004, 6:19    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
Sure, no problem!
I'll need to check the color name at home.
The antenna amplifier and the buzzer in the instrument cluster are connected via a single wire. Therefore, if the buzzer sounds when the door is open and the radio is on, then the antenna amplifier is also receiving power.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 09-09-2026, 5:28.
faz
Avatar-faz
1994 Audi 80
Post12-08-2004, 12:57    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
What kind of original radio was installed?
You don't need any active system adapters.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 09-09-2026, 5:29.
faz
Avatar-faz
1994 Audi 80
Post12-08-2004, 13:08    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
If it's an Alpha or Beta system, meaning without any active system, then the connector I (red) is not present. However, around mid-1994, this red connector was changed from a 10-pin ISO connector to a 20-pin Mini-ISO connector.
http://home.arcor.de/f.bichlmeier/mforum/B4_Radio.jpg
Hopefully, this answers your question about the pin configuration. I'm not sure if it matches the official configuration. As you can see, there's no original switched power cable. You'll need to run that separately from the ignition switch. But it's not a problem, and the cable is quite short icon_wink.gif.
MfG faz
Otto
Post13-08-2004, 0:03    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
'The original radio was already missing in my car! However, the problem was solved when I realized that both the buzzer and the antenna amplifier were powered by the same wire.'
Thank you for your help.
Andreas.
Translated on 09-09-2026, 5:30.
faz
Avatar-faz
1994 Audi 80
Post13-08-2004, 8:01    Subject: VW Golf B4 TDI: Radio Installation Guide Quote
It was a bit strange for me.
The cable to the antenna amplifier was located under the center console/ashtray. It was not connected. So, I would definitely test to see if it's actually connected to pin 5. Measure it at the antenna amplifier.
MfG faz
Translated on 09-09-2026, 5:31.
