Loud Rolling Noises: Causes and Solutions
Rey
Post18-08-2004, 14:22    Subject: Loud Rolling Noises: Causes and Solutions Quote
Hello everyone,
'For about a week now, the rolling noise from one tire (rear left) has become very loud. It's a consistent, even noise, not a clicking or clacking sound.'
It completely disappears in left turns, but becomes even louder in right turns.
What could it be? The tire pressure is correct, the tread depth is 4mm, and there are no visible signs of damage.
Greetings.
Rey.
Translated on 30-10-2026, 6:02.
coolio
Post18-08-2004, 14:58    Subject: Loud Rolling Noises: Causes and Solutions Quote
I'd suspect the wheel bearing. Jack up the car and turn the wheel; you should be able to hear if the wheel bearing is broken.
Translated on 30-10-2026, 6:03.
wollif
Post19-08-2004, 7:06    Subject: Loud Rolling Noises: Causes and Solutions Quote
That's definitely the wheel bearing; I had the exact same problem. I wouldn't wait too long to fix it; in my Golf, the wheel could already be moved back and forth on the lift icon_eek.gif.
I'm sorry, I don't understand. Can you please rephrase your request?
Translated on 30-10-2026, 6:04.
Georg-TDI
Post19-08-2004, 7:57    Subject: Loud Rolling Noises: Causes and Solutions Quote
I am very familiar with these symptoms (based on my own experience; Golf 2, Golf 3).
It's definitely a wheel bearing. Using the method described above, you'll be able to identify it quickly.
It's probably best to replace both wheel bearings at the same time, since they don't cost much.
While it's not that important for this particular problem, what kind of vehicle are we talking about here?
Best regards, Georg.
Rey
Post20-08-2004, 10:01    Subject: Loud Rolling Noises: Causes and Solutions Quote
First of all, I apologize for not including the vehicle details. It was a Passat 35i, model year 1992, with engine code AAZ.
It was indeed the wheel bearing. I checked it as described, and it was actually louder than the other side. I then replaced it (including the bearings and other components), and sure enough, the noise is gone.
Thank you all.
Rey.
Translated on 30-10-2026, 6:05.
No new posts Loud Engine: Powerbox for More Power Diesel Engine Technology
No new posts BLS Train Noise: Sudden Roar / Pendulum Support? Diesel Engine Technology
No new posts Sudden Blinker Noise: Causes & Fixes On-Board Diagnostics (OBD)
No new posts Incorrect injection timing suddenly occurred. Diesel Engine Technology
