Wurstblinker Guest
24-08-2004, 12:05 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi there,
Does anyone else experience this problem, and can someone tell me what I need to do about it?
Do you need to replace a relay?
The preheating light stays on constantly, and the car itself seems to be overheating.
You're welcome.
Sausage blinkers.
Translated on 16-07-2026, 7:14.
dieter Profi-Schrauber
Joined: 01/27/2003 Posts: 270 Karma: +13 / -0 Location: LK Uelzen
24-08-2004, 12:10 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi there,
If it fails to start, the temperature sensor might be disconnected or faulty, or the glow plug relay could be malfunctioning.
Greetings,
"Dieter" T3 syncro 16 AFN
Translated on 16-07-2026, 7:15.
Wurstblinker Guest
24-08-2004, 12:39 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi Dieter,
'Where is the temperature sensor located, and how can it be tested? The warning light goes off after starting the engine.'
Thank you.
Sausage blinkers.
Translated on 16-07-2026, 7:16.
24-08-2004, 15:28 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
If everything is original, this is one of the two sensors located on the sides of the ZK (likely referring to a control unit or device). The other one is for the temperature display. The third sensor at the front of the ZK is for the after-run pump. One of the cables should be blue/white. Unfortunately, I can't find any resistance values for this sensor. If the sensor has infinite resistance, it is definitely defective. But maybe the cable is just disconnected.
Greetings.
Translated on 16-07-2026, 7:17.
24-08-2004, 15:51 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
I once "cooked out" the sensor – meaning I recorded its characteristic curve while it was bubbling in a pot  .
If I can still find it, I might be able to include it inline  .
The colleague's name is 049 919 501 and can be adopted at any Volkswagen dealership for €22. Transparency, Teamwork
Translated on 16-07-2026, 7:18.
Profile PM Garage |
Wurstblinker Guest
24-08-2004, 15:59 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Are you referring to one of the temperature sensors located on the water flange of the cylinder head?
Then I'll go ahead and replace it.
Sausage blinkers.
Translated on 16-07-2026, 7:19.
24-08-2004, 16:37 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Willst Du ihn nicht erstmal messen und das Kabel prüfen?
Profile PM WWW Garage |
