Timing Belt Replacement Audi 80 B4 TDI
muehlenmerlin
Post24-08-2004, 17:52    Subject: Timing Belt Replacement Audi 80 B4 TDI Quote
HI,
I would like to ask, at this point, how important it is to adjust the injection timing after replacing the timing belt on a 1.9L TDI Audi 80 B4, manufactured in December 1994.
Audi's repair manual warns very strongly about a potential hazard, while Bosch's kit doesn't emphasize it much. Has anyone had any experience with this? And besides the normal replacement procedure, what else should be taken into consideration?
Translated on 16-09-2026, 19:42.
joergs
Post24-08-2004, 18:25    Subject: Timing Belt Replacement Audi 80 B4 TDI Quote
I've already replaced several ZRs. Also, each time, I've adjusted the start time of the subsidy. Theoretically, you don't necessarily need to do that, but it's definitely recommended.
If you want to know something specific, then you should ask a specific question! icon_exclaim.gif
Translated on 16-09-2026, 19:43.
wolfi_b
Post24-08-2004, 19:41    Subject: Timing Belt Replacement Audi 80 B4 TDI Quote
Okay, I've already replaced the timing belt myself, and then adjusted the fuel injection timing using VAG-COM. But you can also do it with a regular analog voltmeter! (I've done that too, and it works great!)
Instructions can be found in the technical articles.
I haven't really noticed any real change, but it just feels much better. icon_wink.gif
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 16-09-2026, 19:44.
muehlenmerlin
Post25-08-2004, 21:02    Subject: Timing Belt Replacement Audi 80 B4 TDI Quote
Thank you for the quick responses; they were really helpful!
Best regards, Muehlenmerlin.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing Belt Replacement 1 Diesel Engine Technology
No new posts V6 TDI Timing Belt Replacement, AFB Diesel Engine Technology
No new posts Timing Belt Replacement for Audi VW Fiat Diesel Engine Technology
No new posts Timing belt replacement AJM Diesel Engine Technology
