Brake line routing on the ABS hydraulic block
Jockel
Karma: +15 / -1   Thank you, like it!
Post07-08-2004, 19:54    Subject: Brake line routing on the ABS hydraulic block Quote
I purchased a used ABS system from a Passat manufactured in 1995.
"and I would like to know which wheel is connected to which brake line fitting."
connected to the hydraulic block.
Perhaps one of you has the same system and can kindly...
Please check and let me know.
Here are 2 more pictures:
[img][/img]
[img][/img]
Thanks & bye, Jockel.http://www.rapsinfo.de/tmp/abs1.jpg{MARKER}http://www.rapsinfo.de/tmp/abs2.jpg{MARKER}
"Neu": Bora Variant, ASV
Back to top Profile PM Email
Jockel
Post27-08-2004, 17:49    Subject: Brake line routing on the ABS hydraulic block Quote
Does anyone have a similar system and can check it?
Post27-08-2004, 17:52    Subject: Brake line routing on the ABS hydraulic block Quote
Something isn't working correctly with the linked images.
Once I opened them directly through the page, they are now also displayed here. I only saw two X's before.
If anyone else is having trouble seeing the images, here's the link:
[url][/url]
[url][/url]
@JockelViewing profile: Jockel: Unfortunately, I can't help you.http://www.rapsinfo.de/tmp/abs1.jpg{MARKER}http://www.rapsinfo.de/tmp/abs2.jpg{MARKER}
Marco
Post27-08-2004, 18:49    Subject: Brake line routing on the ABS hydraulic block Quote
Unfortunately, it's not working for me either, even with the link.
Post27-08-2004, 22:41    Subject: Brake line routing on the ABS hydraulic block Quote
Yes, it seems there's a real problem; I can't open them either.
Jockel
Post28-08-2004, 10:45    Subject: Brake line routing on the ABS hydraulic block Quote
Enjoy your meal!
After seeing the pictures at home and at work, I...
I understand that it works everywhere, sorry.
Here it is again:
http://mitglied.lycos.de/joachimbub/sonstige%20Bilder/abs1.jpg
http://mitglied.lycos.de/joachimbub/sonstige%20Bilder/abs2.jpg
Hi, Jockel.
No new posts VW Car Engine Codes: Type, MKB, GKB, AKB, MJ Technical Data
No new posts VW Commercial Vehicle Type Designation, Engine Code, Gear... Technical Data
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Replace Brake Lines: Cost & Installation Guide Transmission, Chassis, Body & Interior
No new posts Kunifer10 Brake Lines: Legal in Germany? Transmission, Chassis, Body & Interior
No new posts Brake Lines VW Golf 3: Replacement Guide Transmission, Chassis, Body & Interior
No new posts What does the TÜV say about these brake lines? Transmission, Chassis, Body & Interior
