Reviving a Pierburg Mass Air Flow (MAF) sensor with an adapter connector?
Post01-09-2004, 13:38    Subject: Reviving a Pierburg Mass Air Flow (MAF) sensor with an adapter connector? Quote
Hi.
I am referring to this article.
Okay, I'm ready. Please provide the German text you want me to translate.
Ulf is writing that you can solder a 22 kOhm resistor between the outer pins to lower the reference voltage.
Can this also be done with the +5V and "sensor output" pins using a pull-up configuration?
Then you wouldn't need to remove the mass airflow sensor (MAF), but instead you could build an adapter plug that would modify the value accordingly.
Is that possible?
Post01-09-2004, 20:43    Subject: Re: Can a Pierburg MAF sensor with adapter connector be "revived"? Quote
dieselmartin wrote:
Ulf writes here that you can solder 22 kOhms between the outer pins to bring the reference voltage down.
Can this also be done with the +5V pins and the "sensor output" as a pull-up resistor?
I wouldn't try that (unless it's on an LLM that's already beyond saving).
If the device has an output similar to that of an amplifier, with low impedance (which I believe is the case), any attempt to distort the output signal would be practically nullified – only the overall power consumption would increase.
The whole thing would probably work with a slightly lower voltage setting, but eventually something would likely burn out.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
