Tuareg Documentary: Drive Train Issues Explained (Solution)
Michael II
Post02-09-2004, 16:39    Subject: Tuareg Documentary: Drive Train Issues Explained Quote
Touareg vehicles with automatic transmissions may exhibit a tension in the drivetrain, accompanied by knocking and rumbling noises from the drivetrain and slippage on the tires.
Cause:
The multi-plate clutch in the transfer case has a residual locking torque due to the control unit and actuator motor. This locking effect is perceived as tension in the powertrain.
Solution:
Check the vehicle for any tension in the drivetrain. Drive through a tight curve while in "D" gear. While in the curve, switch the rotary switch from HIGH to LOW range, while remaining in "D" gear.
If the tension in the powertrain is released, a new control unit must be installed on the transfer case, part number 0AD 927 755 AB.
Actuators without an indexer on the distribution gearbox must also be replaced.
Tschüss
Michael II
Translated on 30-09-2026, 2:20.
Ratings - Tuareg Documentary: Drive Train Issues Explained
No new posts Tuareg Door Lock: Broken Armrest Release Handle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Docs: Idle Vibration Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8D: Documenting Performance Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Drivetrain Issues? Troubleshooting Guide. Diesel Engine Technology
No new posts Clunking Noise in Drivetrain When Accelerating Transmission, Chassis, Body & Interior
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
