TDI Performance Issues: Throttle Valve Solenoid
tk3003
Post08-08-2002, 8:31    Subject: TDI Performance Issues: Throttle Valve Solenoid Quote
hello,
Sure, here is the translation:
'a question:'
My Golf IV TDI sometimes delivers less power than usual, and it feels like the handbrake is being briefly engaged.
The error memory displays the following message:
'Solenoid valve for sugar beet intake - Short circuit to ground' error occurs intermittently.
Deleting it won't do anything, it will just reappear.
'Or something like that.' The VW workshop checked the valve (both mechanically and electronically) and found it to be in good condition. All the cables/pipes leading to the turbo were checked - no signs of leaks. The VTG (Variable Turbine Geometry) was also checked using a vacuum gauge and was okay.
The LMM (lambda measuring module) was replaced as a test – no improvement. Now, even VW is at a loss... They want to conduct a very extensive troubleshooting process and asked me about the budget I'm willing to spend... Of course, this isn't ideal at all... It's essentially an invitation to be overcharged.
Has anyone ever encountered this message before, and do you know how to fix the problem?
Translated on 31-08-2026, 17:48.
eike
Post08-08-2002, 11:23    Subject: TDI Performance Issues: Throttle Valve Troubleshooting Quote
It's strange that some people are getting a specific error message indicating a short circuit in the valve, while others are checking the VTG turbo and the pipes. Can't they read the error message?
So wie ich es sehe, kommen für die Fehlermeldung nur 3 Sachen in Betracht: das Ventil, das Kabel zum Steuergerät und das Steuergerät selbst. Wenn jetzt ein Masseschluß gemeldet wird, könnte ich mir vorstellen, daß irgendwo vielleicht eine Kabelisolation durchgescheuert ist und an Masse kommt. Erstmal würde ich eine Sichtprüfung des Kabelbaumes machen. Ist er beschädigt? Dann die Stecker prüfen. Sind sie beschädigt oder naß / feucht? Als nächstes den Stecker vom Steuergerät abziehen und die Leitungen zum Ventil durchmessen ( auch gegen Masse). Auf Verdacht solltest Du auch mal das Ventil tauschen. Wenn es daß nicht war, kann man das neue evtl. zurückgeben oder bei eBAy verhökern. Vielleicht besteht die Möglichkeit, daß das Ventil intern einen Schluß zwischen auf Masse liegenden Metallteilen (?) und der Spule hat. Manche Fehler findet man nur mit einer erhöhten Prüfspannung ( Isolationsmeßgerät). Vorsicht, dabei unbedingt alle Elektronik von den zu prüfenden Kabeln abklemmen! Ein Multimeter mißt nur mit ein paar Volt, da findet man nicht jeden Fehler. MancThey only appear when there are vibrations, so tap firmly and move the wires while taking measurements.
'When checking the valve coil, you should not only verify its continuity, but also compare its value (resistance) to that of a definitely working valve.'
Good luck with your search. Let me know what you find.
Eike.
Translated on 31-08-2026, 17:50.
Post08-08-2002, 12:18    Subject: TDI Performance Issues: Throttle Valve Solenoid Quote
My throttle valve = shut-off valve (?). Disconnect the vacuum hose from the small, black, round plastic container next to the EGR valve and plug the hose. A plastic lever extends from the plastic container to the shut-off valve/throttle valve (it looks like a throttle valve on a carburetor).
Test drive the car thoroughly and check if the loss of power still occurs.
You might also have a problem with the wiring harness.
Translated on 31-08-2026, 17:51.
tk3003
Post08-08-2002, 14:20    Subject: SEO: Best German to English Translation Services Quote
hi,
First of all, thank you for the tips and suggestions... let's see if I can actually find those parts... I'll keep you updated. If necessary, I can perhaps make a reasonably concrete proposal to the workshop, so they don't continue to fiddle with the turbocharger or other expensive parts and then possibly replace them, simply because it's so profitable... but first, I'll try to figure it out myself - although, unfortunately, I'm not exactly an expert in these things icon_smile.gif).
Translated on 31-08-2026, 17:53.
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS intake flap Upload
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
No new posts ALH Intake Manifold Flap Problem & Fix Diesel Engine Technology
No new posts Intake Manifold Flap Control N239 On-Board Diagnostics (OBD)
