Retrofitting S-contact, what is the effort required?
golf3schrauber
Post08-09-2004, 7:38    Subject: Retrofitting S-contact, what is the effort required? Quote
I would like to retrofit the S-contact on the ignition lock of my Golf.
What exactly needs to be changed?
Is it sufficient to replace both the ignition switch and the locking cylinder together within the ignition switch housing? Or must the housing also be replaced on the steering column?
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
No new posts Lederlenkrad nachrüsten trotz Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Geschwindigkeitsregelanlage nachrüsten Seat IBIZA / Polo Troubleshooting & Guides
No new posts Austausch der Hydrostössel, welcher Aufwand? Diesel Engine Technology
No new posts Automatikgetriebe leckt --> 2000 EUR Aufwand ? Transmission, Chassis, Body & Interior
No new posts A3 8P Relief relay X-contact problem... On-Board Diagnostics (OBD)
No new posts Contact for broken horn Diesel Engine Technology
