Loud Engine Noise: Help! Nail/Knock Sound?
Andreas SHG
Post02-08-2002, 17:54    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
I'm completely desperate; my engine is making a very loud knocking and rattling noise, but...
Normal driving performance, but there's a rattling sound in certain RPM ranges.
almost unable to listen.
The very loud clattering sound is definitely coming from the engine.
VW believes the catalytic converter has failed, but that's not actually the case - ATU confirmed it.
The exhaust system has been checked and it can't help anymore either -- sigh.
OKAY: Passat TDI 110 hp (3B), year of manufacture 1997, 204,000 km.
Translated on 08-08-2026, 14:02.
Post02-08-2002, 18:03    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Unfortunately, you haven't written anything about your vehicle; no one can read minds. icon_rolleyes.gif
Hopefully, you've already checked that nothing is loose on the engine mechanically, as well as the tensioner pulleys for the timing belt and any serpentine belts (if present).
What vehicle? Engine code letter? Mileage? Oil consumption? Recent repairs performed?
Have you checked the injection timing using a diagnostic tool?
When does the knocking/rattling occur less? Is it related to cold or warm engine temperature, low or high RPMs, or low or high torque output?
How is the starting behavior?
Questions upon questions... so go ahead and ask!
Translated on 08-08-2026, 14:04.
Andreas SHG
Post02-08-2002, 18:11    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Hopefully, you've already checked that nothing is loose on the engine mechanically, as well as the tensioners for the timing belt and any serpentine belts (if present).
Questions upon questions... so go ahead and start!
The A.T.U workshop checked everything from the outside, and the noise is coming from inside.
Stand besonders laut, bei ca. 2500 Umdrehungen klappert es fast nicht mehr. Ansonsten ist eigentlich alles im grünen Bereich. A diagnosis.
It hasn't been done yet, but I will go to the workshop again tomorrow.
to rattle.
Volkswagen Passat 1.9 TDI 3B 110 HP, 205,000 km
Translated on 08-08-2026, 14:07.
Post02-08-2002, 18:12    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Are the motor mounts in good condition? To check them, engage first gear, turn off the engine, open the hood, and then push the vehicle firmly forward and backward.
We are observing how much the engine tilts.
Translated on 08-08-2026, 14:09.
Post02-08-2002, 18:15    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Check if the alternator and power steering pump (if equipped) are securely mounted. I once lost a mounting bolt for the alternator.
Translated on 08-08-2026, 14:10.
Andreas SHG
Post02-08-2002, 18:38    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Are the motor mounts in good condition? To check them, engage first gear, turn off the engine, open the hood, and then push the motor firmly forward and backward.
Greetings, Rainer.
I forgot to mention that the Passat has a 4-speed automatic transmission.
has.
The sound is coming from the engine casing - *sniff...*
Translated on 08-08-2026, 14:11.
wolfman2
Post02-08-2002, 21:53    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
If it only occurs at very low speeds and disappears later at higher speeds, you should specifically check the front drive belt, especially the tensioner damper (a spring with an internal damper). A defective damper will make a noticeable rattling noise.
Translated on 08-08-2026, 14:12.
Andreas SHG
Post03-08-2002, 8:29    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
If it only occurs at very low speeds and disappears later at higher speeds, you should specifically check the front drive belt, especially the tensioner damper (a spring with an internal damper). If the damper is defective, it will make a noticeable rattling noise. icon_eek.gif
Good tip - thank you - I will check it out right away. }
Arne
Post05-08-2002, 10:29    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
I had the same thing last week.
You could only see it on the stage, and we didn't even realize what it was until an hour later. It was a bolt from an engine mount. It had come loose, which caused vibrations, rattling, and clunking noises.
Try getting on a lift, leaving the engine running, and then get underneath it to try and listen where the noise is coming from.
Could you try hitting it with a hammer? If it makes a noise when you hit it there, then it's definitely broken.
Otherwise, as Rainer already mentioned. Check the screws on the power steering pump, alternator, transmission, etc. Pay particular attention to those that are attached to the engine mounts, as described above.
Perhaps the exhaust pipe is rattling, but you wouldn't notice it when it's on the stage because the axles aren't under load and are in a different position than they would be during normal operation.
Perhaps it's the exhaust pipe attachment point at the rear axle.
I know how to drive someone crazy.
Arne.
Translated on 08-08-2026, 14:14.
Rudi
Post09-08-2002, 10:59    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Hello Rainer,
I once tried this on my car (which tends to rattle quite a bit) and managed to get it about 3-4 cm.
Do you (or someone else) have any idea how far the motor is allowed to move icon_question.gif?
Translated on 08-08-2026, 14:16.
Uwe
Post09-08-2002, 11:46    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Hi!
It's also possible that the turbocharger has internal damage. This can cause rattling or knocking noises, and it won't necessarily reduce power if it's still spinning. What is the exact relationship between the noise and the engine speed?
Best regards, Uwe.
Translated on 08-08-2026, 14:17.
Post09-08-2002, 11:46    Subject: Motor Movements: Understanding and Analysis Quote
Hello Rudi,
Mine also moves about the same distance!
Translated on 08-08-2026, 14:18.
Post09-08-2002, 11:50    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Hello Rudi,
You can't just say that in general; it also depends on how firmly you push things back and forth. In any case, nothing should be loose or able to shift around.
In my case, it was clearly visible that the engine mount on the left side (facing forward) had shifted its position on the engine side, which is not supposed to happen. Consequently, it tilted more than your reported 3-4 cm.
I then disassembled the casing and added an extra rubber strip because the rubber inside was somewhat crumbly/worn out.
Since then, he's been driving more calmly, and there are no more noises coming from the car.
Ideally, a new engine mount would have been the best solution, but if it works this way too...
Translated on 08-08-2026, 14:19.
Rudi
Post09-08-2002, 12:04    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Thank you for your quick response.
@Uwe:
It usually rattles at low speeds/when starting.
@Bertil:
Then, at the very least, the range of motion due to the motor mounts is 'normal.'
(or yours has the same quirk icon_cool.gif).
@Rainer:
ich muß am Wochenende sowieso Öl wechseln. WLet's take a look.
How the rubber looks.
Translated on 08-08-2026, 14:21.
Post09-08-2002, 18:20    Subject: Loud Engine Noise: Help! Nail/Knock Sound? Quote
Rudi wrote:
@BertilViewing profile: Bertil:
Then, at the very least, the range of motion due to the motor mounts is "normal."
"Um... when I attach the trailer hitch, something hits the engine or something nearby and makes a noise. I haven't been able to find out what it is yet. The engine mounts are all new except for the one near the turbo."
Translated on 08-08-2026, 14:22.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6: Loud Ticking/Knocking Noise - Fix! Diesel Engine Technology
No new posts 1.9 TDI ATD: Engine Noise When Starting Diesel Engine Technology
No new posts TDI Timing Help: Strange Error Message? On-Board Diagnostics (OBD)
No new posts tdi 1Z; Loud whistling... Diesel Engine Technology
