Golf 4 TDI: Howling Noise - Causes & Fixes
Klima96
Karma: +6 / -1   Thank you, like it!
Post06-09-2004, 14:31    Subject: Golf 4 TDI: Howling Noise - Causes & Fixes Quote
Hello.
My Golf 4 TDI PD with a 6-speed manual transmission is making a strange howling noise.
If I'm rolling through the countryside in 5th gear without giving it any gas, especially at around 60 km/h icon_sad.gif.
I immediately went to the friendly VW workshop manager, and after a test drive, he...
A saw-tooth pattern has been detected on the rear tire! A clear diagnosis!!! icon_rolleyes.gif
I've noticed that when I press the clutch while hearing the squealing noise...
The noise disappears and then reappears immediately when I take my foot off the clutch.
The noise is also faintly audible in the 4th and 6th gears.
Could that probably not be the cause of the saw-tooth pattern? icon_question.gif
Original tires !!! 22,000 km driven !!!
Translated on 22-10-2026, 17:50.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post06-09-2004, 15:42    Subject: Golf 4 TDI: Howling Noise - Diagnosis & Repair Quote
Klima96 wrote:
Hello.
"Saw-toothing pattern detected on the rear tire! Definite diagnosis!!! icon_rolleyes.gif"
Sequential tire fitting !!! 22000 KM driven !!!
So, as a certified automotive mechanic, you should be able to tell whether the noise is coming from the transmission or from the tires! icon_lol.gif
I'm ruling out the tires.
Maybe some other damage will creep in, which will make the diagnosis easier for you. icon_twisted.gif
I once had a BMW with faulty bearings in the transmission, and that's what it sounded like.
Like a turbine engine, its output speed increased continuously as it accelerated.
B.Eng (FH) u. KFZ Meister
Translated on 22-10-2026, 17:53.
Michael II
Post06-09-2004, 15:46    Subject: Golf 4 TDI: Howling Noise - Causes & Fixes Quote
Please provide the model year, engine code, and transmission code.
Could this be it?
Tschüss
Michael II
Translated on 22-10-2026, 17:54.
Klima96
Post06-09-2004, 16:13    Subject: Golf 4 TDI: Howling Noise - Causes & Fixes Quote
Hello.
First registration: 11/2002.
MKB: ASZ
GKB: ERF
Since the new car warranty is about to expire, I would like to get a quick repair done by VW.
achieve. What options do I have in case of a gearbox failure?
Is it possible to get rid of these costs for free in the coming years?
Is a written saw-tooth diagnosis sufficient?
Translated on 22-10-2026, 17:55.
Post06-09-2004, 16:37    Subject: Golf 4 TDI: Howling Noise - Causes & Fixes Quote
So, go check it out and be thorough. If the noise changes when you press the clutch, it's probably not the tires.
I've found that if you directly tell the guys at VW what you want and politely but firmly point out that their diagnosis is nonsense, they make more of an effort. Otherwise, directly state that you need written confirmation from them regarding a possible transmission problem, for future warranty/goodwill claims, and that you will, of course, also be contacting VW directly about this matter. Then, they will either cooperate, or the issue will escalate to VW.
By the way, I also have the ASZ ERF combination, and I can assure you that there's no whining noise coming from the transmission.
"Have there been any issues related to shifting problems, or is everything working perfectly? Apparently, a different type of oil was used in that transmission to resolve problems, replacing G052171A2 with what was considered a better alternative, G057126A2. However, my transmission already has that oil in it, and it was manufactured in July 2002."
Translated on 22-10-2026, 17:57.
Klima96
Post10-09-2004, 20:18    Subject: Golf 4 Whining Noise: Causes & Fixes Quote
Hello.
I went to the VW workshop again yesterday and spoke with the master mechanic and the workshop manager.
Test drove it. I was able to clearly demonstrate that when you press the clutch...
The noise disappears. The two experts then quickly move on.
The saw blade has lost its teeth!
But no one really knew where the problem might be.
- Riding incorrectly (You shouldn't be in the 5th gear if you're going below 60 km/h).
- Normal sounds (hypersensitivity)
- Vibrations in the gear linkage.
- Any issues with the transmission?
And so on. I heard some really funny things!
I'm not completely stupid, you know!
It could originate from anywhere. I had the diagnosis put in writing so that I could also...
to still be treated with understanding even after the warranty period has expired.
I once heard something about drive shafts making noises!
Does anyone have any information about this? I think they were probably swapped with someone else.
Golf 4 TDI PD 96 KW 6 Gang ASZ ERF
Jetzt 114 Kw nach *** Chip
Translated on 22-10-2026, 17:59.
Markus H.
Post10-09-2004, 23:52    Subject: Golf 4 TDI: Howling Noise - Causes & Fixes Quote
How about a wheel bearing?
It might be a bit early considering the mileage, but anything is possible.
A gearbox failure would be far too premature...
I know this problem from personal experience.
The howling noise disappeared as soon as I disengaged the clutch (otherwise, it was audible at a constant speed of 80 km/h).
After replacing the wheel bearing (for a different reason), this noise disappeared.
'However, we should still investigate the possibility of a transmission problem!'
Don't let my silly suggestion cause you to miss out on your warranty coverage!
Translated on 22-10-2026, 18:02.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Whining during coupling Diesel Engine Technology
No new posts Engine Whine: Is It a Turbo Problem? Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
