Exhaust fumes again!
donalexo
Post13-09-2004, 12:18    Subject: Exhaust fumes again! Quote
Hello everyone!
I know this topic has been discussed before, although in a slightly different context.
In short, the reason for this new thread is our "new" TDI in the garage. I've noticed that the G4 ALH has a distinct smell of "sulfur," that sharp, sulfurous odor that is also emitted by some CDIs.
My A3 smells completely different, even with the new injectors. The injector replacement campaign resulted in a noticeable "improvement" in exhaust smell towards a "new car" scent for my A3 AGR, but it's still significantly behind the exhaust smell of the G4 ALH.
Okay icon_wink.gif.
My suspicion falls on the EGR valve, which is completely functional in the G4 but defective in my A3. Has anyone specifically investigated this before?
Probably, I will be able to answer the question myself soon, because I have such a strong feeling that the EGR valve of the G4 will break down very soon icon_wink.gif.
I would still be very interested in learning more about "sniffing experience"!
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 21-07-2026, 6:44.
Rudi
Post13-09-2004, 12:49    Subject: Exhaust fumes again! Quote
Hi Alex,
My 1Z smells different than the other small 1Zs, even with the nozzles currently installed.
(I wouldn't have thought of violets, though icon_cool.gif).
It may be due to the fact that the nozzles have an opening pressure of 220 bar (which is unusual for a 1-zone system).
apart from the hole diameter icon_twisted.gif).
Best regards, Rudi.
Translated on 21-07-2026, 6:46.
joergs
Post13-09-2004, 13:10    Subject: Exhaust fumes again! Quote
Does it smell like violets with you? In my winter A4 with the AFN engine, it smells extremely strongly of french fries, and in the 1Z, it smells like grilled chicken, but not quite as bad. icon_razz.gif
Translated on 21-07-2026, 6:47.
Post13-09-2004, 13:56    Subject: Exhaust fumes again! Quote
My car just smells awful... ugh.
When I got a new catalytic converter about a year ago (because part of the flexible pipe was defective), it also smelled much more like rotten eggs.
Now I notice that when running in normal city traffic, it almost smells like a swirl chamber. But if I really push it with a full throttle burst and then let off, it definitely smells more like diesel.
This was all while the EGR system was still active (although it wasn't functioning correctly according to the MAF values).
It broke down for me over the weekend.
Next time, I'll use PIESEL to make it burn more gently.
Translated on 21-07-2026, 6:48.
Holger247
Post13-09-2004, 14:09    Subject: Exhaust fumes again! Quote
Hi donalexo,
How many kilometers has your new horse covered in rides so far?
When I received my ALH with 40,000 km (approximately 25,000 miles), it still smelled quite strongly of ozone. Now, at almost 120,000 km (approximately 75,000 miles), I think the smell has changed more towards a diesel odor. My EGR should still be working; I've cleaned it twice already.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 21-07-2026, 6:50.
Post13-09-2004, 14:17    Subject: Exhaust fumes again! Quote
@HolgerViewing profile: Holger
That's not ozone; those are nitrous gases that have a smell very similar to chlorine.
Translated on 21-07-2026, 6:51.
WarLord
Post13-09-2004, 21:12    Subject: Exhaust fumes again! Quote
Hmm, ours smells very differently. When I start it cold, it stinks terribly of old diesel. But when it comes into the garage warm, it usually smells like CDI. It seems to have something to do with the catalytic converter temperature.
Best regards, WarLord.
Post13-09-2004, 21:26    Subject: Exhaust fumes again! Quote
Oops, you guys have noses...
We have both CDI and TDI engines here... I usually walk past the front of the cars when they're running. I know that my TDI Golf smokes a little bit bluish-gray in the morning (when reversing out of the carport on a very steep incline), which indicates an issue with the AGR valve. On the Passat, the AGR is okay, but it smokes really black in the morning on the same stretch of road. And the W202 220 CDI smokes the whole spectrum of colors that combustion engines can produce in the morning.
P.S.: I usually only notice this (in all three cases) when driving in the winter with the lights turned on early in the morning... you can hardly see anything during the summer.
But I don't think I smell violets; it smells more like the port of Hamburg when something arrives from the Far East.
Translated on 21-07-2026, 6:53.
No new posts Exhaust fumes inside the cabin, VW T6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Stuttering in 1Z: Troubleshooting Guide Diesel Engine Technology
No new posts Clutch Failure: Common Causes & How to Fix It Diesel Engine Technology
No new posts Clutch Problems: Common Issues and Solutions Diesel Engine Technology
No new posts ZKD Failure: Replacing After 45,000 km Diesel Engine Technology
