Boost Pressure Curve Golf 4 1.9 TDI
tannen
Post28-08-2004, 18:10    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
Hello.
Problem: The vehicle has poor traction.
Yesterday, I performed a diagnostic test using VCDS and logged the turbo pressure.
The pressure was almost always close to the displayed setpoint. Is it normal for the pressure to fluctuate constantly? I always thought it would be more stable.
eventually settle at a certain value.
Okay, yes. The air mass flow is also too low. I think that's related to the turbo pressure.
Could it also be that the turbo pressure is acting up due to a faulty mass airflow sensor?
How can I safely test the boost pressure control system?
Translated on 18-09-2026, 23:35.
Marco
Post28-08-2004, 18:37    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
Just post the log. Then we won't have to guess.
Translated on 18-09-2026, 23:36.
Post29-08-2004, 13:34    Subject: TDI Boost Pressure: Golf 4 1.9 Performance Quote
tannen wrote:
Is it normal for the pressure to constantly fluctuate? I always thought it would eventually settle at a certain value.
Oh yeah, the mass airflow is also too low.
That fits perfectly.
Translated on 18-09-2026, 23:37.
Post29-08-2004, 15:03    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
I've moved it to this new thread. Please don't always create a new thread!
tannen wrote:
These are from a Golf4 TDI. The vehicle has poor acceleration.
http://mitglied.lycos.de/vagseiten/ladedruckmessung1.CSV
http://mitglied.lycos.de/vagseiten/ladedruckmessung2.CSV
http://mitglied.lycos.de/vagseiten/luftmasse.CSV
Could someone please take a look at this?
Best regards
Translated on 18-09-2026, 23:38.
AndreasG
Post30-08-2004, 13:41    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
Please review the troubleshooting articles, especially.
A quick test using the diode described there will immediately and easily show you whether the mass airflow sensor is faulty or if the problem lies elsewhere -> technical article.
Please mention your mileage and the total distance driven next time.
tannen
Post19-09-2004, 19:31    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
Hello.
First of all, SORRY about the previously opened thread that was unnecessarily created. It was an accident icon_redface.gif.
The mass airflow sensor (MAF) was defective in the vehicle.
I have one more question regarding VCDS (Vag-Com).
When I log group 11 (boost pressure), I see a line showing the current boost pressure and another showing the target pressure. Is the target pressure curve recalculated, so that it would also be incorrect in case of a defect? Or is it stored in the control unit? (In other words, if the actual pressure follows the target pressure curve, it's a good indication that the boost pressure control is working correctly?)
Translated on 18-09-2026, 23:40.
Post20-09-2004, 16:40    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
tannen wrote:
When I log group 11 (boost pressure), I see the line showing the current boost pressure and another showing the target pressure. Is the target pressure curve recalculated, and therefore incorrect in case of a defect, or is it stored in the control unit? (In other words, if the actual pressure follows the target curve, it's a good indication that the boost pressure control is working)??????
Normally (meaning: under normal external conditions), the target pressure is, as far as I know, primarily determined based on the throttle position and the current RPM, using a lookup table – regardless of any defects in the engine.
As long as "Ist" is equivalent to "Soll," then the arrangement is okay.
Translated on 18-09-2026, 23:41.
tannen
Post20-09-2004, 20:12    Subject: Boost Pressure Curve Golf 4 1.9 TDI Quote
Thank you for the answers.
Spruce trees.
Translated on 18-09-2026, 23:42.
No new posts Boost Pressure Curve Diesel Engine Technology
No new posts Boost Pressure Behavior: Strange or Normal? Diesel Engine Technology
No new posts Boost Pressure & Air Mass: Explained Diesel Engine Technology
No new posts Boost Pressure: Is My Log Correct? On-Board Diagnostics (OBD)
