I'm relatively new to the field of diagnostics, but I've managed to do some digging and found the following information 'online':
Control Module Part Number: 1M0 035 186 K
Component and/or Version: Radio GRO 2.29
Software Coding: 00401
Workshop Code: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Okay, so there seems to be something wrong with the antenna. Can someone explain to me exactly what it is?
Is the antenna completely detached, or is there a problem with the power supply?
Can I actually clear the error (in memory)? And if the hardware error isn't fixed, will it reappear (in memory), or will it be gone permanently then?
THX.
Translated on 29-07-2026, 6:00.
