Lighting: Types, Benefits & Installation Guide
honkbert
Post14-08-2002, 10:35    Subject: Lighting: Types, Benefits & Installation Guide Quote
I'm having a problem with my lighting. Only the low beam and the high beam flash work. However, when I switch on the high beam, everything goes dark. The fuses and bulbs are fine. The switch is only available as a complete unit with all the controls, and it's not cheap. So, until I'm sure that the switch is the culprit, I'll leave it for now.
The car is a 1993 Audi 80 TDI.
Perhaps someone can help me.
Thank you very much.
Holger.
Translated on 24-10-2026, 11:49.
Varianti
Post14-08-2002, 13:29    Subject: Lighting: Types, Benefits & Installation Guide Quote
Then try disconnecting the connector from the light switch/horn and bridging the corresponding pins. That way, you'll see what happens. Of course, you'll need a wiring diagram.
'Addendum:'
If the high beam doesn't work, it's very likely the switch. This is because the high beam relay also operates through the high beam switch.
Translated on 24-10-2026, 11:50.
No new posts A2 Doku: Faulty Combination Light - 8Z0 MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MJ 2002: Flickering Lights & CD Player Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Illumination of ventilation ducts Transmission, Chassis, Body & Interior
No new posts AC & Lighting: Solutions for Your Comfort Diesel Engine Technology
No new posts Climatronic Lighting: Installation & Troubleshooting Transmission, Chassis, Body & Interior
No new posts VW Blue Ambient Lighting: Specs & Details Diesel Engine Technology
