LDA: Is it worth it?
Arno
Post05-10-2004, 20:44    Subject: LDA: Is it worth it? Quote
Hello.
I want to buy an LDA and I came across this.
I've never heard of that manufacturer before, and according to Google, they only produce kitchen equipment for the restaurant industry icon_lol.gif.
Does anyone have one of these or know more about it? And do you think this LDA is actually any good (it looks like a regular pressure gauge)?
Translated on 17-08-2026, 2:43.
SeatLeon
Post05-10-2004, 21:03    Subject: LDA: Is it worth it? Quote
This LCD has a diameter of 67 mm, which is not the common size of 52 mm. Brackets, stands, and displays with similar dimensions are likely to be difficult to find.
Translated on 17-08-2026, 2:44.
datsun
Post06-10-2004, 8:08    Subject: LDA: Is it worth it? Quote
Okay, the quality looks good. However, I don't see any use for the -1 bar setting.
'Furthermore, I think a damper is missing because otherwise the pointer will flutter.'
But that can be achieved by...
But if the price is right.
Rainer.
Translated on 17-08-2026, 2:45.
Avatar-Jan6K
Post06-10-2004, 8:14    Subject: LDA: Is it worth it? Quote
The main question you can only answer yourself: Do you have space in your car where this item will fit?
All other parameters look good – I would only miss a finer scale division between 0 and 0.5.
January.
1Z5 CFHF / AHB H4D
Translated on 17-08-2026, 2:46.
wolfi_b
Post06-10-2004, 8:32    Subject: LDA: Is it worth it? Quote
@Jan6KViewing profile: Jan6K
Do you think a division of 0.1 bar is too coarse?
Or did you overlook the fact that it only appears as if there is no scale division between -0.5 and 0.5 due to a shadow?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
BigB
Post06-10-2004, 8:44    Subject: LDA: Is it worth it? Quote
I find it a bit suspicious.
He writes in big letters: 'no plastic parts,' but the T-connector is clearly made of plastic, which he can't deny. And the hose connection to the T-connector is secured with cable ties. What's the point of having hose clamps then?
I don't think it's sufficient for a system that operates with pressure and pressure fluctuations.
You could try replacing it; take a look at www.wassergekuehlt.de, they have something like that made of metal with a coupling nut, which should definitely hold.
Best regards, BigB.
Translated on 17-08-2026, 2:47.
Avatar-Jan6K
Post06-10-2004, 9:07    Subject: LDA: Is it worth it? Quote
Or have you overlooked the fact that it only appears as if there is no scale division between -0.5 and 0.5 because of a shadow?
The latter – one should really take a closer look at the images for more than just a fleeting moment.
"I think a resolution of 0.1 is sufficient, even though I appreciate that my digital LDA allows me to see fluctuations of around 20 mBar. However, a finer scale division wouldn't change anything in that regard; it would just make things less clear."
January.
1Z5 CFHF / AHB H4D
Translated on 17-08-2026, 2:49.
Georg_G
2012 Volkswagen Golf
Post06-10-2004, 13:16    Subject: LDA: Is it worth it? Quote
Rainer
The negative range is already quite good. It allows you to monitor the function of the shut-off valve.
Best regards, Georg.
Translated on 17-08-2026, 2:51.
Post06-10-2004, 16:54    Subject: LDA: Is it worth it? Quote
... and to detect potential charger damage (of a specific origin) early on, preventing situations where you are completely at their mercy -> Expert article on LDA (Load Detection Analysis).
Arno
Post06-10-2004, 17:22    Subject: LDA: Is it worth it? Quote
@everyone: Thank you for the responses.
Oh, sorry, I completely overlooked the unusual diameter of 67 mm in the heat of the moment (well, those who can read have a clear advantage icon_twisted.gif). The offer also includes a link to a video where you can't really see much, but in my opinion, the display doesn't seem to be flickering. Yesterday, that same vendor sold an LDA for 26 [currency unit].
It's a bit too big for me, because it would require some modifications to install it. Time will tell... icon_wink.gif
Translated on 17-08-2026, 2:53.
No new posts Is this box worth buying? Diesel Engine Technology
No new posts Decoding: What does this code mean? On-Board Diagnostics (OBD)
No new posts Identify This Wheel: Car Rim Help & Info Transmission, Chassis, Body & Interior
No new posts Will these rims fit? Transmission, Chassis, Body & Interior
