Deactivate AGR via Control Unit
Frosch2
Post15-08-2002, 16:23    Subject: Deactivate AGR via Control Unit Quote
I found an instruction manual under http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html (which, of course, isn't as good as here icon_wink.gif) on how to adjust the EGR valve via the control unit. Supposedly, if you don't overdo it, the exhaust values should remain within the normal range.
What do you think about this possibility? Wouldn't that then be legal? It seems to work, and you probably wouldn't notice much, maybe just a slightly more direct response.
I think this is a good, good compromise.
Happy tinkering...
Translated on 30-10-2026, 0:23.
Post15-08-2002, 17:27    Subject: Legal or Illegal: What You Need to Know Quote
Hi.
Adjusting the AGR (Abgasrückführung) rate using VAG-COM or a similar tool would, in my opinion (based on a gut feeling), be considered a borderline case.
As long as the emission limits specified in the type approval are met, things should be fine - but who can really put a "sophisticated" emissions analyzer next to it for comparison?
And finally: the "ultimate" goal – preventing (new) oil sludge deposits in the intake manifold – can only be achieved by completely decommissioning the system.
And then, as far as I know, the nitrogen oxide emissions will definitely exceed all local regulatory limits.
Therefore, the "trick" using VAG-COM is essentially just a reduction, but not a real solution to the problem.
Translated on 30-10-2026, 0:25.
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mazda 323F DITD: Disable AGR (Exhaust Gas Recirculation) Diesel Engine Technology
No new posts AKN: Partial Power Outage Affects Service Diesel Engine Technology
No new posts LLC Effects: Some Mysteries Unveiled? Diesel Engine Technology
No new posts Defective Comfort Electronics: Troubleshooting & Repair On-Board Diagnostics (OBD)
