Idle Speed with AC On: Troubleshooting & Tips
DeathAngel69
Post16-08-2002, 18:27    Subject: Idle Speed with AC On: Troubleshooting & Tips Quote
Hello.
It is widely stated that the engine idle speed should increase when the air conditioning is turned on. Or does this only refer to maintaining a certain speed? Mine remains at 945 RPM, regardless of whether the AC is on or off icon_smile.gif.
Is that okay?
Translated on 25-07-2026, 15:12.
Post16-08-2002, 19:35    Subject: Carburetor Idle Speed Adjustment Quote
When you turn on the air conditioning (if it was originally installed), the control unit (ECU) is notified, and the engine speed is slightly increased to ultimately return to its original value.
My (retrofit) air conditioning system doesn't have that feature, and as a result, the engine struggles quite a bit even when idling!
By the way, the original KIMA system can also be deactivated by the TCU (Transmission Control Unit) under certain conditions: during kickdown, within 6 seconds after engine start, and when the engine temperature reaches critical levels.
Translated on 25-07-2026, 15:13.
Markus H.
Post16-08-2002, 20:23    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
That's exactly how it is.
When the air conditioning compressor is activated via the magnetic clutch, the engine speed drops slightly, even with the original KA system.
I have a 'free rider question' (and don't want to start a separate thread for it):
Lately, I've been reading repeatedly that the refrigerant should be replaced after a few years because it gradually degrades over time, and the compressor could fail.
Now I've noticed (after 7 years without any maintenance), that the radiator fan is starting up more frequently when the air conditioning is on, which used to only happen during extreme heat or in 'hurricane' ventilation mode.
Does this indicate a low refrigerant level in the system?
Or does it simply indicate a declining performance of the cooling fins, which are supposed to get dirty over time?
Translated on 25-07-2026, 15:15.
DeathAngel69
Post16-08-2002, 21:06    Subject: Climate Miracle: Solutions for a Sustainable Future Quote
Hi again!
Thank you for the quick responses!
I converted a gasoline automatic car into a TDI manual transmission car myself, therefore I can't really provide the solutions that a new car would have. icon_smile.gif
As soon as I press the button on my air conditioning system, the fan turns on. Regardless of the weather or location. So, turning on the AC means the fan is set to level 1.
Level two, depending on the heating and cooling requirements.
Perhaps this will help you?
Best regards.
Nic @ DeathAngel69
Translated on 25-07-2026, 15:17.
Markus H.
Post16-08-2002, 22:22    Subject: Okay, hier ist eine mögliche Übersetzung: "Best German Translation Services - Get a Quote" Quote
...in fact, fan speed level 1 is always running.
I wasn't entirely accurate:
The second stage is happening more and more frequently for me, which is causing me some concern.
Translated on 25-07-2026, 15:19.
Post17-08-2002, 7:16    Subject: Re: Exactly Quote
I have a "free rider question" (and don't want to start a separate thread for it):
Lately, I've been reading repeatedly that the refrigerant should be replaced after a few years because it gradually degrades over time, and the compressor could potentially fail.
Now I've noticed (after 7 years without any maintenance) that the radiator fan is starting up more frequently when the air conditioning is on, which used to only happen during extreme heat or in the most powerful ventilation mode.
Or does it simply indicate a declining performance of the cooler fins - which are supposed to get dirty over time, right?
Yes, the information is correct, and your assumption about it is also correct.
For retrofitted air conditioning systems (especially those with rubber hoses, which can be even more extreme!).
Translated on 25-07-2026, 15:21.
No new posts Chainsaws in Climate Control: A Guide Transmission, Chassis, Body & Interior
No new posts Increase idle speed with VAG-COM? Diesel Engine Technology
No new posts Adjust Idle Speed: How-To Guide On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Idle Speed Fluctuations: Causes & Fixes Diesel Engine Technology
