Woran gehen Lader bei getunten Motoren kaputt? | Posts 16+
Go to page: Previous  1, 2
faz
Avatar-faz
1994 Audi 80
Post15-10-2004, 17:59    Subject: Quote
ulf wrote:
faz wrote:
The displacement limit will not play a role in our discussion (unless someone drastically increases the engine displacement icon_wink.gif)
I think it can play a role because it limits the mass flow through the compressor.
And that's precisely why using a turbocharger increases the mass airflow compared to a naturally aspirated engine -> The higher the boost pressure, the greater the mass airflow, even with the same displacement.
Das schon auch, aber da schlägt eher Pumpgrenze oder max. Drehzahl als Grenze an. I see.
Perhaps it would be helpful to plot a representative curve for a 1.9L engine with known turbocharger behavior under full load onto a characteristic map of a VNT15 turbocharger.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 27-07-2026, 14:06.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts A3 Transmission Problems: 3rd, 4th, 5th Gear Not Working? Diesel Engine Technology
No new posts Loader Problems: How to Diagnose G2 TD Issues Diesel Engine Technology
No new posts VP37: Common Issues & Problems in Old Age Diesel Engine Technology
No new posts MSA15 Control Unit: How to Identify a 1Z Model? On-Board Diagnostics (OBD)
