OBD2-Adapter | Posts 32+
Go to page: Previous  1, 2, 3
DocSnydor
Post12-08-2002, 9:13    Subject: Quote
Since I didn't have a plug, I had to insert the bare wires... The ground is connected to the capacitor, but not the 12 volts. I also don't understand where those 12 volts are supposed to be coming from. On the PDF schematic, it's directly connected to 12V, but in the picture of Jeff Noxon's circuit board, it doesn't seem to be!
Translated on 04-07-2026, 4:14.
Post12-08-2002, 9:36    Subject: Quote
"In my opinion, it should also fit on the PCB layout, since the connection from the positive terminal of C1 goes directly to the 9-pin connector?"
[img][/img]
Best regards, Rainer.http://www.dieselschrauber.de/Temp/pcb-b1.jpg{MARKER}
Translated on 04-07-2026, 4:15.
Gremlin
Post12-08-2002, 12:11    Subject: Quote
Okay, I can't understand what's going on. I strictly followed the wiring diagram, and I assembled the 'layout' using stranded wire to save space. The wiring diagram is absolutely correct. Both interfaces worked perfectly right from the start and still do to this day.
'Hey, you should carefully double-check your wiring against the schematic diagram. There's definitely a mistake or a misaligned component somewhere. And of course, remove the components as much as possible beforehand (I've socketed the optocouplers and transistors).'
Are all the resistors okay? Did you accidentally install a 100 ohm resistor instead of a 10k ohm resistor?
Are the optocouplers correctly connected?
CU Gremlin.
Translated on 04-07-2026, 4:16.
Varianti
Post12-08-2002, 13:23    Subject: Quote
Yes, and if you are using the BC546 or 547 transistors, be aware that the pinout is different (the collector and emitter pins are swapped). If not, then BANG, and you'll need new transistors.
The flattened side should face away from the optocouplers.
Translated on 04-07-2026, 4:17.
DocSnydor
Post18-08-2002, 15:32    Subject: Quote
Sorry, I couldn't access the internet for a while because my DSL connection stopped working due to the flooding.
@ Rainer: I really missed that spot you circled, or I didn't take it seriously enough. Now my capacitor has 12V, but the adapter still isn't being recognized.
Probably, after all the experimenting, some component might be broken now. But I don't feel like starting all over again. I've had enough.
I definitely want to thank everyone who tried to help me. Thanks, guys!!!
Best regards.
David.
Translated on 04-07-2026, 4:18.
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts OBD2 for TDCi On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostic Adapters: Buy Now! On-Board Diagnostics (OBD)
