Engine Cleaning: PD TDI with Steam Cleaner?
herwigw
Post15-10-2004, 15:56    Subject: Engine Cleaning: PD TDI with Steam Cleaner? Quote
Since I'm planning to try and unscrew something on my Bora soon (to check the NW position), I'm wondering how water-resistant the engine and other components are – it could actually use a good engine wash.
With my 1986 Passat, I would occasionally use a steam cleaner to clean the engine, both after oil changes and at other times - and it handled it without any problems. Of course, I know that this isn't necessarily the case for every car; the Passat was just a robust vehicle.
Has anyone had negative experiences with engine cleaning?
Can I wash it with the engine cover removed? (It tends to be particularly dusty and a bit oily there.)
Are there any delicate parts that I should be more careful with (alternator, etc.)?
Best regards and have a nice weekend.
herwig
Translated on 03-09-2026, 13:49.
Julian
Post15-10-2004, 16:01    Subject: Engine Cleaning: PD TDI with Steam Cleaner? Quote
I also gave my AWX a thorough cleaning in the summer. I don't like it when dirt and grime accumulate in the engine compartment. Nobody enjoys working on it when it's like that.
Removing the engine cover is straightforward. Use a degreaser, let it sit for a while (5-10 minutes, depending on the product instructions!), and then rinse it off with cold water.
I would advise being very careful around the connectors and generator, otherwise you might force water in. The engine compartment is splash-proof, but not waterproof.
If possible, disconnect the connectors and then dry them with compressed air. However, this is not mandatory.
Translated on 03-09-2026, 13:51.
herwigw
Post15-10-2004, 19:11    Subject: Engine Cleaning: PD TDI with Steam Cleaner? Quote
If possible, disconnect the plug connectors and then dry them with compressed air. However, this is not mandatory. icon_cool.gif
Using compressed air to dry things is definitely a good idea!
After there were no cries of outrage from the suffering forum members, I will go ahead and do it on Saturday; hopefully, he will have recovered from my 'horse therapy' by Sunday at the latest }.
Translated on 03-09-2026, 13:52.
To
Post15-10-2004, 20:01    Subject: Engine Cleaning: PD TDI with Steam Cleaner? Quote
I would cover the fuel tank, battery, and brake fluid reservoir, and then work with low water pressure and as much distance as possible from the engine and other components.
Tobias.
Translated on 03-09-2026, 13:53.
D.
Post17-10-2004, 11:27    Subject: Engine Cleaning: PD TDI with Steam Cleaner? Quote
I've never had a motor wash done on any of my vehicles.
Why all of this?
If you start 'tinkering' around like that, you're bound to get dirty fingers anyway!
Translated on 03-09-2026, 13:54.
No new posts Engine wash Diesel Engine Technology
No new posts Engine Cleaning: What to Consider Diesel Engine Technology
No new posts Alternator Failure After Engine Wash A3 ALH? Diesel Engine Technology
No new posts A4 B7: Fan Stays On After Engine Cleaning Diesel Engine Technology
