Turbocharger for 1Z Engine: 110 HP Upgrade?
Cisco
Post16-08-2002, 12:26    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Quote
Good day.
I was wondering if the turbocharger from a 110 horsepower engine would fit on a 1Z engine. The 1Z engine has an ECU chip. I don't know the engine code for the 110 horsepower engine.
Cisco.
Translated on 22-08-2026, 17:00.
Post16-08-2002, 12:56    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Quote
No.
Translated on 22-08-2026, 17:01.
Markus H.
Post16-08-2002, 21:13    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Translating...
schnupfi
Post20-08-2002, 19:06    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Quote
I don't think that's quite right.
To convert a 1Z engine to an AFN, you need a bit more than just that. I think you'll need the engine control unit (ECU), turbocharger, fuel injection pump, and injectors.
You should probably ask a specialist or post here again.
Greetings.
Sneezy.
Translated on 22-08-2026, 17:02.
Golfmann
FaBu likes this.
Post21-08-2002, 0:31    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Quote
Hi.
You can modify the turbocharger!
Then you'll need a different exhaust manifold, you'll have to adapt the EGR connections, and you'll need a second control valve for the turbocharger (or you can use the one from the EGR system – which nobody needs anyway, since they're the same). The downpipe is also different. As far as I know, the fuel injection pump is larger, and so are the injectors. And finally, there's a different engine control unit because the turbocharger operates with negative pressure rather than positive pressure.
I think you can probably skip the pump and injectors and just adjust the tuning box a bit. But you definitely need everything else.
The AFN engine also has other valves and stronger bearings.
The Golfman.
Translated on 22-08-2026, 17:03.
Stukov
Post21-08-2002, 13:56    Subject: Turbocharger for 1Z Engine: 110 HP Upgrade? Quote
As I understand it, he was asking if he could simply bolt the turbocharger from an AFN engine onto his 1Z engine, not whether he could convert his 1Z to an AFN. It's likely that he wanted to know if using the AFN turbocharger as a direct replacement is possible without major modifications.
Translated on 22-08-2026, 17:04.
Post21-08-2002, 16:43    Subject: Magnetic Valves: Turbocharger & EGR Systems Quote
Golfmann wrote:
... you need a second control valve for the turbocharger (or you can use the one from the EGR system, since nobody needs that anyway), because they are the same.
Hi.
Objection:
1. Every driver who wants to legally drive around without a specific type approval needs an EGR solenoid valve.
2. The engine control unit monitors whether both valves are stuck; if they are, error codes will be generated.
3. The valves are not always the same; some have black caps and others have white caps, and they differ in their cross-sectional area for the vacuum path.
Therefore, this results in different response characteristics for each respective control loop icon_idea.gif.
Translated on 22-08-2026, 17:06.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injector: AFN 110PS Fits 1Z 90PS? Diesel Engine Technology
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts Adjusting a turbo-diesel engine Diesel Engine Technology
No new posts TDI (110 hp) engine failure! Diesel Engine Technology
